Karl_Mac_ Posted February 14, 2014 Report Share Posted February 14, 2014 Evening chaps. My fuel filler cap lock doesn't appear to work. The lock turns but doesn't seem to lock the cap. Is this a common problem?If I have to replace it do I need to replace all the other locks? Quote Link to comment Share on other sites More sharing options...
shearermax Posted February 14, 2014 Report Share Posted February 14, 2014 just buy one with a key and have a separate key for the fuel Quote Link to comment Share on other sites More sharing options...
stator Posted February 15, 2014 Report Share Posted February 15, 2014 Mine also doesn't work. It appears to lock but you can just twist it out even when it's locked. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted February 15, 2014 Report Share Posted February 15, 2014 I never even lock it Quote Link to comment Share on other sites More sharing options...
Rich Posted February 15, 2014 Report Share Posted February 15, 2014 I don't even know if any of the three have a lock. Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 16, 2014 Report Share Posted February 16, 2014 (edited) Mine locks but I regularly forget. Doubt anyone is going to steal your fuel lol....Do Lupo's have anti-siphoning devices? I tried to siphon some diesel out of my own SDI once and failed miserably and ended up going round the local garage with a jerry can. Edited February 16, 2014 by Skezza Quote Link to comment Share on other sites More sharing options...
Paul Posted February 19, 2014 Report Share Posted February 19, 2014 Evening chaps.My fuel filler cap lock doesn't appear to work. The lock turns but doesn't seem to lock the cap. Is this a common problem?If I have to replace it do I need to replace all the other locks?Mine had the same problem recently. I went to VW to ask about a replacement and they wanted about £50. So, my Dad took apart my fuel cap and found that a piece of white plastic had broken. I bought a fuel cap from a scrapped Lupo on eBay for £5 and we took that one apart, transplanted the plastic part into mine, and now my original one works again Alternatively, you could do as shearermax said and buy a generic one from a motor factors. I did that until I bought the Lupo one but it was annoying having a different key and I missed that thing where you can place the Lupo one on top of the filler cap whilst you fill up! Quote Link to comment Share on other sites More sharing options...
stator Posted February 20, 2014 Report Share Posted February 20, 2014 Mine had the same problem recently. I went to VW to ask about a replacement and they wanted about £50. So, my Dad took apart my fuel cap and found that a piece of white plastic had broken. I bought a fuel cap from a scrapped Lupo on eBay for £5 and we took that one apart, transplanted the plastic part into mine, and now my original one works again Alternatively, you could do as shearermax said and buy a generic one from a motor factors. I did that until I bought the Lupo one but it was annoying having a different key and I missed that thing where you can place the Lupo one on top of the filler cap whilst you fill up! Don't suppose you have any photos to show the broken bit? Quote Link to comment Share on other sites More sharing options...
Paul Posted February 20, 2014 Report Share Posted February 20, 2014 Don't suppose you have any photos to show the broken bit?I'll see what I can do over the weekend Quote Link to comment Share on other sites More sharing options...
Dblock Posted February 21, 2014 Report Share Posted February 21, 2014 I always lock mine. Just habit I suppose. Good info from Paul it may be a small part that is changeable. Quote Link to comment Share on other sites More sharing options...
Paul Posted February 23, 2014 Report Share Posted February 23, 2014 As promised, here are pictures to show how my Dad and I repaired my fuel cap that appeared to lock, but then unscrewed.I bought a fuel cap from a Lupo that was being broken for parts and then we carefully dismantled it so that we could transplant a part that had broken in my original one. This is the fuel cap. You'll need to prise out the rubber seal with a flat-bladed screwdriver. Then, using the screwdriver, prise the locking part from the rest of the cap. You'll then have this. The locking barrel lifts out. The white plastic part on the right is the part that broke in my original fuel cap. The broken part is shown just below it. The white plastic part and the spring fit into the chamber at the bottom of the lock barrel. To remove them (and fit the new one in), lift up this clip. Then pull the lock barrel out a little way. Then you can put the spring and the white plastic part in place. You'll need the key to ensure it's unlocked and you may need to move the key around in the lock to ensure the white plastic part is seated properly. Then push the lock barrel back into place, replace the clip, and in the spirit of Haynes manuals, 'refitting is a reversal of removal' 1 Quote Link to comment Share on other sites More sharing options...
stator Posted February 23, 2014 Report Share Posted February 23, 2014 Wow great photos. Thanks for sharing Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 24, 2014 Report Share Posted February 24, 2014 Paul's post should probably be put into the How To section. Great post! Quote Link to comment Share on other sites More sharing options...
Ray Singh Posted May 7, 2020 Report Share Posted May 7, 2020 Ive got the same issue and was excited to find this thread - the pictures will not work - any ideas please? Quote Link to comment Share on other sites More sharing options...
mk2 Posted May 7, 2020 Report Share Posted May 7, 2020 I've never managed to syphon fuel out of a lupo, even if nearly full. There's that wierd kink in the filler pipe and blow back arrester (little spring loaded button right inside the filler neck). Why lock it? Quote Link to comment Share on other sites More sharing options...
C3peteo Posted May 7, 2020 Report Share Posted May 7, 2020 I just bought a new fuel cap from ebay for a few quid. Means another key on the key ring. Wish I'd not thrown the original one in the bin now. Quote Link to comment Share on other sites More sharing options...
Rich Posted May 7, 2020 Report Share Posted May 7, 2020 I currently have a nice one with a key. I also have a few spare locks to match it. I syphoned a Lupo the other day by poking the fuel line directly into the tt tank and hooking 12v up to the fuel pump, easy and painless. Quote Link to comment Share on other sites More sharing options...
mk2 Posted May 8, 2020 Report Share Posted May 8, 2020 Yeah I do the same on my SDIs when I need a can of diesel- feed the bleed line into a can while the engine is running. It pumps it out for you in minutes :) Quote Link to comment Share on other sites More sharing options...
Ray Singh Posted May 8, 2020 Report Share Posted May 8, 2020 I managed to change the whole thing and its working now. This site was a great help: https://www.t4-wiki.de/wiki/Tankdeckel Be careful. its quite a delicate set of parts. 1 Quote Link to comment Share on other sites More sharing options...
