Kes Posted February 1, 2014 Report Share Posted February 1, 2014 Does anyone find the obd connector gets stuck? Happened to me on 3 different cars. Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 1, 2014 Report Share Posted February 1, 2014 Does anyone find the obd connector gets stuck? Happened to me on 3 different cars. you mean it's tight? To be fair, it's supposed to be. It shouldn't slip off easily. Quote Link to comment Share on other sites More sharing options...
Kes Posted February 1, 2014 Report Share Posted February 1, 2014 Sorry I mean stuck as in wont come off without excessive force. Much tighter that a normal obd2 cable. I have to use so much force it feels like something might break. Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 2, 2014 Report Share Posted February 2, 2014 Nope. That does sound a little bit extreme. It should come off fairly easily... Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 3, 2014 Report Share Posted February 3, 2014 (edited) Finally calibrated it yesterday. It's not 100% accurate yet but it's not far off. It required a 344% correction on the fillup Perhaps the previous owner was using it on a motorbike. Unfortunately, once you get to three digits, you lose the decimal point lol. Fine for the moment it shouldn't be too far off next fillup at which point I can correct it Not had chance to replace the board yet, going to use this one for a week then change it, then I'll let you know if it's really worth the £15 upgrade. Edited February 3, 2014 by Skezza Quote Link to comment Share on other sites More sharing options...
jon_273 Posted February 3, 2014 Report Share Posted February 3, 2014 344% doesn't seem right. Have you converted from litres to US gallons? Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 3, 2014 Report Share Posted February 3, 2014 Yep. Is that wrong? It's certainly reading a lot more accurate now. The scan gauge thought I'd used 1.8 gallons when I'd used over 5. Full tank to quarter. It's a second hand one so I'm guessing it was calibrated for the previous owner. A factory reset won't clear the fill up data. Like I said,I think it was being used on a bike because the engine size was set at 0.7 so... Quote Link to comment Share on other sites More sharing options...
jon_273 Posted February 3, 2014 Report Share Posted February 3, 2014 No, I think that's how I did it although it was a while ago. It'll probably sort itself out after a couple of tanks. Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 25, 2014 Report Share Posted February 25, 2014 Is it time to remove the grill blocking yet? It's getting warm outside. Quote Link to comment Share on other sites More sharing options...
Dblock Posted February 25, 2014 Author Report Share Posted February 25, 2014 Just depends on your temps. Mind warns up quick and still isn't going over 90 so I'm good ATM. Quote Link to comment Share on other sites More sharing options...
jon_273 Posted February 25, 2014 Report Share Posted February 25, 2014 I still don't fully understand why you need to block your grille and I don't. You must use the heater too much :s Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 25, 2014 Report Share Posted February 25, 2014 I still don't fully understand why you need to block your grille and I don't. You must use the heater too much :sPerhaps your coolant is low To be fair, your concerns should be to Dblock because he has a TDi and they tend to run warmer. I'm in an SDI which are notorious for running cold. Even in the summer, my SDI doesn't usually go above 80 degrees lol... Quote Link to comment Share on other sites More sharing options...
Dblock Posted February 25, 2014 Author Report Share Posted February 25, 2014 I still don't fully understand why you need to block your grille and I don't. You must use the heater too much :sMaybe so but I live in Scotland and generally drive when it's dark so colder too. Also let's say all things equal with my grill block my car will heat up much quicker than yours so if we both went to the shops mine would be heated faster than yours equaling better mpg. Quote Link to comment Share on other sites More sharing options...
jon_273 Posted February 26, 2014 Report Share Posted February 26, 2014 Yes I was aiming it at Dblock and the other TDI owners generally. Coolant should be fine as it's less than 2 years old. Dblock has yours got a decat? As that made mine take longer to warm up. Quote Link to comment Share on other sites More sharing options...
Dblock Posted February 26, 2014 Author Report Share Posted February 26, 2014 Yes I was aiming it at Dblock and the other TDI owners generally. Coolant should be fine as it's less than 2 years old. Dblock has yours got a decat? As that made mine take longer to warm up.No although I do want to get one fitted. With it being a little warmer now the car heats up pretty quickly. E.g. car from cold 4/5c will go to about 50c in about 5mins now which is great. My coolant was changed when I changed the stat too. Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 26, 2014 Report Share Posted February 26, 2014 Coolant should be changed every five years although it's probably worth changing it more often. I use an anti freeze tester. Quote Link to comment Share on other sites More sharing options...
Dblock Posted February 26, 2014 Author Report Share Posted February 26, 2014 Coolant should be changed every five years although it's probably worth changing it more often. I use an anti freeze tester.Five years seems very long? I'd say 2 years max personally. Quote Link to comment Share on other sites More sharing options...
Skezza Posted March 10, 2014 Report Share Posted March 10, 2014 Re-routed my cabling up my steering column. Looks the bees 1 Quote Link to comment Share on other sites More sharing options...
lupo_ro Posted January 25, 2016 Report Share Posted January 25, 2016 Does anyone mounted ScanGauge E on a Lupo 1.0? How many date reports? AVG, MPG? Please tell me. I wish one of these. Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 27, 2016 Report Share Posted January 27, 2016 On 25/01/2016 at 8:57 PM, lupo_ro said: Does anyone mounted ScanGauge E on a Lupo 1.0? How many date reports? AVG, MPG? Please tell me. I wish one of these. Mounting a ScanGauge is easy mate. Trust me  Worth doing as well imo. On my 1.0E (when I had it) I got roughly 40MPG on a good run, maybe 45MPG if I was very lucky. If driven hard, they'll drop to low 30's. Quote Link to comment Share on other sites More sharing options...
lupo_ro Posted January 27, 2016 Report Share Posted January 27, 2016 Thanks. I will buy one from ebay next mounth. Cheers! Quote Link to comment Share on other sites More sharing options...
