wanting to 6-speed tdi
Keelan
Nope no straight fit, the AMF engine never had a 6 speed mated in any other VAG model.
You need the bell housing to match, however people have manage to adapt a JDD 6-speed from a Polo blue motion
http://www.a2oc.net/forum/showthread.php?22012-BlueMotion-Gearbox-(JDD)-fitted-into-1-4-TDI-AMF-engine
The JDD they are referring to is a 5 speed. No Polo BlueMotion's have a 6 speed box. They do talk about a 6 speed conversion but couldn't see any more info about it (on the first page of the thread anyway). D you have any more details? As I have discussed this with my gearbox specialist and he couldn't think of one that would fit and have suitable ratio's for a diesel.
I want to get a tdi and put a six speed box in it but I don't know much about gearboxes.
Is there one or a non OEM brand that fit the bill?
You can get a kit from eurotuning but it will cost you about £1500-£2000. A JDD gearbox is also good but is longer throughout. The best bet is to change the 5th gear out for a longer one.
That's interesting. It's pretty much how VW made the GTI 6 speed box (take a 5 speed, and fit an elongated end plate). Not cheap though is it. I think I'd rather just change the 5th gear cog...
Edited by jon_273
Thats my thing with it. It's perfect apart from the price. The 5th gear swap is much much much more price effective. Some people also say the polo bluemotion gearbox can fit. The code is JDD.
What would you change the 5th gear cog with? I'd like to do the same thing but with my 5speed lupo gti
a slice of cheese most likely.
On the tdi there is 3 or 4 options. 0.700, 0.681, 0.65, 0.625. All will lower revs in 5th gear. 0.625 will mean 70mph at 2krpm in a tdi. Would that work in a gti? I don't know.
what sort of rev range would you have to be in from fourth to go into fifth do you reckon?
  • 5 months later...
Hello,
package price is £ 890
http://www.eurotuning.cz/images/image/en/optimizing/index.html
Regarda EuroTuning
Hi is that fitted?
Still can't find the part numbers for the longer gears but apparently the gears are only available in commercial tps. Will try to find out anyways.
Edited by Dblock
How muh torque is the kit rated for?
Hello,
Our set of parts stands the same torque like the gearboxes Volkswagen 02A, 02J.
Volkswagen specifies the maximum torque with 250 Nm for these gearboxes ensuring long-term life time of the gearbox.
We provide the same warranty for our parts like VW does.
We use neither gears nor other parts from VW, our parts are special and we manufacture them at the same quality as VW does.
If you tell us the gearbox code, we will create a chart for gear ratio we can offer you.
Regards, EuroTuning
