Uggi Posted November 15, 2013 Report Share Posted November 15, 2013 Hi folks!, just joined the forum, I live in Orkney and bought a Lupo sdi a few weeks ago as a project since the timing belt had snapped with the previous owner, its back in use, but there has been a lot of niggly wee problems, but they are getting less now too! lolI gleaned a lot of tips from this site for a lot of the problems, and thought I would join so I can add my tuppence worth if I can help.CheersAndy Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 17, 2013 Report Share Posted November 17, 2013 Welcome!What's on the to do list for the SDI? Quote Link to comment Share on other sites More sharing options...
Uggi Posted November 17, 2013 Author Report Share Posted November 17, 2013 Hi, I have been out working on it last night, so there is not a lot left to do now. Story so far is,I bought the car for £100 as it had been towed to a garage with a snapped timing belt. So I took the head off and apart to see what it was needing. so to get it going again it needed;8 Tappets - as they were all "domed" (got these and the guides out of an old Inca 1.9sdi van)3 New valves - bent quite bad3 Valve guides - scored quite badly taking out the bent valves8 New valve stem oil seals Cam oil sealHead gasket setTiming belt kit - full kitWater pump - Just to be on the save sideEGR Blanking plate - what a mess was in the inlet sideRemoved the inlet air restrictors and gave the ports good clean and a light polishNew oil, oil filter, fuel filter and air filter.That got it running, but sadly the spending had to continue lol, so I bought the following;Front discs and padsRear drums, shoes and cylinders - still waiting on drums £22 a PAIR on ebay, was quoted £65+vat EACH at local factors!Track rod endsRemote locking kit - doddle to fit with this site's how to section(i wired the indicators wire to the hazard switch)Various bulbs - interior, dash, headlight, high level brake light needed new connections made!Last night I did;4 new glow plugs - as it was a bit "white smokey" on a cold start up. I got denzo fast heat up ones off ebay £6 odd each.New temp sensor - What a difference as it used to rev itself when I was starting it (hot or cold) and the glow plug light light was staying on for ages. cheap fixHeater resistor - no more only fan speed 4!So the to-do list only has; Gearbox oil seal - at least!fit the back brakes when the drums arrive(from France!)tidy up the body work - after incident involving pressure washer and bonnet's laquer DOH!do something with the ultra soft suspension, don't want to go much lower, just stifferprobably alloys at some point, but must fit the winter wheels tonight as we have snow forecast for the start of the week!Thats the story so far, I bet you are sorry you asked!! lol 1 Quote Link to comment Share on other sites More sharing options...
grovey Posted June 15, 2014 Report Share Posted June 15, 2014 hihave a lupo thats indicators have packed up. \the hazards work so i know the bulbs work as do alll the fuses. Now the wipers are not working.Can anyone helpGrovey Quote Link to comment Share on other sites More sharing options...
jgee Posted June 23, 2014 Report Share Posted June 23, 2014 Think you should just go to a sparky grovey, would be a bit unsafe to use the car without them and the problem sounds to be getting worseAlso Uggi your hardly a noob lol Quote Link to comment Share on other sites More sharing options...
