Joenoone96 Posted November 13, 2013 Report Share Posted November 13, 2013 I only have one drink holder, would It be much work to fit another? Quote Link to comment Share on other sites More sharing options...
Silver! Posted November 13, 2013 Report Share Posted November 13, 2013 No, just pull the coin tray out of the housing, whilst disengaging it with a small implement. Slot the cupholder into place and push home.The cupholder itself isn't sided, but the fascia is. You can put your coin tray fascia on if you have the wrong side c\holder one. Pull off from the bottom.Assuming you have DIN type, the coin tray will be on the left. Quote Link to comment Share on other sites More sharing options...
Joenoone96 Posted November 13, 2013 Author Report Share Posted November 13, 2013 No, just pull the coin tray out of the housing, whilst disengaging it with a small implement. Slot the cupholder into place and push home. The cupholder itself isn't sided, but the fascia is. You can put your coin tray fascia on if you have the wrong side c\holder one. Pull off from the bottom. Assuming you have DIN type, the coin tray will be on the left. my coin try won't seem to budge, won't come out Quote Link to comment Share on other sites More sharing options...
Silver! Posted November 14, 2013 Report Share Posted November 14, 2013 Try removing the whole unit and trying. Pull radio out, the just pull the unit out. Quote Link to comment Share on other sites More sharing options...
