Jimmie77 Posted September 20, 2013 Report Share Posted September 20, 2013 HiI just got myself a Lupo 01 1.4 (but with a 1.6 16v inside)Problem i have with it is that the airbag lights up on the console. And further more it shows no error code on that?!I have no idea whats been done on the car prior to my ownage. What is wrong with it?The codes i get is P0106 and P013A. Quote Link to comment Share on other sites More sharing options...
Derv Posted September 20, 2013 Report Share Posted September 20, 2013 If the airbag light is staying on, then there should be a code stored.Those codes you have are engine fault codes, so you need to check the airbag circuit. Quote Link to comment Share on other sites More sharing options...
Jimmie77 Posted September 20, 2013 Author Report Share Posted September 20, 2013 yes i know its Engine codes, but those are the only codes that show up.where is the ciruit i should check? how do i go about this?About the Engine codes it was suggested that the Throttle housing (if thats the correct name) is dirty. Quote Link to comment Share on other sites More sharing options...
Derv Posted September 20, 2013 Report Share Posted September 20, 2013 You need to use something better than the OBDII reader to access the airbag circuit, something like VCDS.Those OBDII codes are Lambda and MAP sensor related. Another thread with a related title may get you more help here. Quote Link to comment Share on other sites More sharing options...
Jimmie77 Posted September 21, 2013 Author Report Share Posted September 21, 2013 Im not sure i understand.The codes came from a reader with Bluetooth and cellphone. Since then i purchased a reader on my own with USB. And i was going to do Readings for my own in the future vith Vag-Com. Unfortunatly my Laptop runs a x64 Win7 and it doesnt seem to work on that. Anyways are you saying that it will not do with that kind of Equipment? Quote Link to comment Share on other sites More sharing options...
Derv Posted September 21, 2013 Report Share Posted September 21, 2013 VCDS x64 is working fine here. OBDII is only required to do engine codes. That is why you cannot read the airbag fault. Quote Link to comment Share on other sites More sharing options...
Jimmie77 Posted September 21, 2013 Author Report Share Posted September 21, 2013 It does?! send it over =PBut do i get this right. Stuff plugged in via the OBDII cannot read this? where do you read it then from? Quote Link to comment Share on other sites More sharing options...
Derv Posted September 22, 2013 Report Share Posted September 22, 2013 Generic OBDII readers are only concerned with emission related faults. You need VCDS or something that can also read the other codes.Get yourself a lead and go here >>> VCDS. Quote Link to comment Share on other sites More sharing options...
danoid Posted September 23, 2013 Report Share Posted September 23, 2013 I've got U281 scanner, that checks engine faults and airbags.Suggest investing in one, very cheap and you can clear your warning then, but if it comes back something is amiss Quote Link to comment Share on other sites More sharing options...
Jimmie77 Posted October 3, 2013 Author Report Share Posted October 3, 2013 i managed to get the code. here:1 fault found:01217 - Side airbag igniter: Driver side (N199) 29-10 - Short to Ground - IntermittentWhere the hell is the side airbag?! Quote Link to comment Share on other sites More sharing options...
Jimmie77 Posted October 5, 2013 Author Report Share Posted October 5, 2013 Ok so there are airbags on the seat. i saw them today. Quote Link to comment Share on other sites More sharing options...
danoid Posted October 5, 2013 Report Share Posted October 5, 2013 Sounds like they've been taken out, but someone didn't disconnect the battery, or didn't use the correct air bag adapter.You could try disconecting the battery on the car for an hour, but I think it won't clear it, will need a scanner u281 will do, only a tenner Quote Link to comment Share on other sites More sharing options...
Jimmie77 Posted October 5, 2013 Author Report Share Posted October 5, 2013 Cant i clear it with VAG-COM? And i dont Think its been removed. I asked the previous owner when it started to lid up, and it was previous this year and for no appearent reason Quote Link to comment Share on other sites More sharing options...
danoid Posted October 5, 2013 Report Share Posted October 5, 2013 yer vcds will clear it, as its called these days Quote Link to comment Share on other sites More sharing options...
Derv Posted October 7, 2013 Report Share Posted October 7, 2013 Clear the code and see if it comes back. It may be an old fault. Quote Link to comment Share on other sites More sharing options...
Jimmie77 Posted October 7, 2013 Author Report Share Posted October 7, 2013 i cleared it and it didnt come back at once anyway. Quote Link to comment Share on other sites More sharing options...
Jimmie77 Posted October 7, 2013 Author Report Share Posted October 7, 2013 btw in VCDS i cant seem to read the "Engine". say bad sync rate or something. whats up with that? Quote Link to comment Share on other sites More sharing options...
danoid Posted October 7, 2013 Report Share Posted October 7, 2013 Hmm, I have this sometimes and is very stressful.Guessing your using VCDS-Lite? and a ebay lead?If so, try plugging it in, then switch on ignition, then scan, if it doesn't work, scan it then remove key.If not, it could be problems with baud rates etc but google your problem and it should give you some help. Quote Link to comment Share on other sites More sharing options...
Jimmie77 Posted October 7, 2013 Author Report Share Posted October 7, 2013 yeah baud it said something about. and i prolly have the "lite" version Quote Link to comment Share on other sites More sharing options...
