Skezza Posted January 1, 2014 Report Share Posted January 1, 2014 In another thread, I took a picture of a bleed valve I used to help clear air when I sucked it in doing a diesel purge. Quote Link to comment Share on other sites More sharing options...
GeoffD Posted January 2, 2014 Report Share Posted January 2, 2014 skezza, the bleed valve is a bung for the pipe cos you ran out of injectors! does the job though. geoff Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 3, 2014 Report Share Posted January 3, 2014 skezza, the bleed valve is a bung for the pipe cos you ran out of injectors! does the job though. geoff that's the kid. Worked perfectly for me Quote Link to comment Share on other sites More sharing options...
DennisCK Posted January 3, 2015 Report Share Posted January 3, 2015 Hey, Skezza and Geoff. I also have this problem. At high speeds my car wont accelerate beyond a specific point and this is very noticeable going uphill as I can't even pass the slow going trucks and buses.I didn't understand the last two parts that you guys wrote. It might be due to slang. Did everything work out in the end. Switching engines sounds like an expensive experience?Anyway, I drive the 1.3 TDI Lupo and I also thought about the fuel filter until reading this post. Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 3, 2015 Report Share Posted January 3, 2015 Dennis your issue sounds like cast iron fuel filter.I would also do a diesel purge just before you change your fuel filter. It'll restore the spray pattern and improve performance. Quote Link to comment Share on other sites More sharing options...
mk2 Posted January 5, 2015 Report Share Posted January 5, 2015 EGR causing air passage blockage, but computer still supplying same amount of fuel (so running really rich)??? see my inlet plenum thread with pics of the problem... Now totally cured and awesome! Quote Link to comment Share on other sites More sharing options...
