bg02gar Posted August 13, 2013 Report Share Posted August 13, 2013 Need all the brains on here to help me out please So my gti has overheated twice now , first time i noticed i had no water left in the coolant bottle so i topped it up, < this was about a week ago. But i drove it again 2 days ago and it did it again but the bottle was still full from when id topped it up. ( so no leaks) .Also i took it out for a spin today and im not sure if its just me but i thought it was a bit slow , I've also checked my oil which is fine.hit me pleaaasseeee 1 Quote Link to comment Share on other sites More sharing options...
Tsd Posted August 13, 2013 Report Share Posted August 13, 2013 check your thermostat Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 13, 2013 Report Share Posted August 13, 2013 If there was no coolant in the expansion tank it has a leakWhen was the waterpump last changed? Quote Link to comment Share on other sites More sharing options...
bg02gar Posted August 13, 2013 Author Report Share Posted August 13, 2013 water pump was changed 3/4 weeks ago along with cambelt now the trouble ( wonder if they fobbed me off.... mmm) Quote Link to comment Share on other sites More sharing options...
GTIChris Posted August 13, 2013 Report Share Posted August 13, 2013 Did you make sure there was no air lock when you refilled the tank ? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 14, 2013 Report Share Posted August 14, 2013 I'm guessing he didn't do it himself Chris, so won't have checked.You are right though, could be an airlock if its recently been drained Quote Link to comment Share on other sites More sharing options...
bg02gar Posted August 14, 2013 Author Report Share Posted August 14, 2013 ive not checked to see if its air locked, how do i go about this? cheers Quote Link to comment Share on other sites More sharing options...
GTIChris Posted August 14, 2013 Report Share Posted August 14, 2013 Take the cap off the header tank and repeatedly squeeze the pipes to the rad. You're basically trying to make it 'burp' any air out of the system. Quote Link to comment Share on other sites More sharing options...
bg02gar Posted August 14, 2013 Author Report Share Posted August 14, 2013 ok thats been done Quote Link to comment Share on other sites More sharing options...
bg02gar Posted August 14, 2013 Author Report Share Posted August 14, 2013 how will i know if the water pump gone then? Quote Link to comment Share on other sites More sharing options...
GTIChris Posted August 14, 2013 Report Share Posted August 14, 2013 Did you have the engine running when you did it and therefore the water pump ? Quote Link to comment Share on other sites More sharing options...
Sophiemasden Posted August 22, 2013 Report Share Posted August 22, 2013 My car did this a few times i put a new temperature sensor on my car it helped a little bit but the problem has come back now Quote Link to comment Share on other sites More sharing options...
bg02gar Posted June 16, 2019 Author Report Share Posted June 16, 2019 I'm still on going with this problem ;( lol been a while Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 16, 2019 Report Share Posted June 16, 2019 Details? Quote Link to comment Share on other sites More sharing options...
bg02gar Posted June 16, 2019 Author Report Share Posted June 16, 2019 can leave the car running, within 15 minutes of stand still I'm over heating. Quote Link to comment Share on other sites More sharing options...
LR5V Posted June 16, 2019 Report Share Posted June 16, 2019 You would give Florence nightingale a run for her money nursing that issue for 6 years! Quote Link to comment Share on other sites More sharing options...
Rich Posted June 16, 2019 Report Share Posted June 16, 2019 Does it do it on a run? If not, fans. Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 16, 2019 Report Share Posted June 16, 2019 Ok, here we go... (I'm assuming good head gasket, normal fuel mixture, ok brakes, ok cat and normal ign timing. is there coolant in the system? does the water pump run ok and circulate coolant? does the thermostat open and keep the temp gauge at 90 without moving once warmed up and driving normally? Is the right thermostat fitted... do the fan(s) work? does the interior heating work? does the coolant level stay constant (no leak or crack somewhere)? does coolant circulate through the radiator (can you feel warm fluid leaving the rad through the hose, when engine is hot?) Quote Link to comment Share on other sites More sharing options...
Sausage Posted June 17, 2019 Report Share Posted June 17, 2019 Do the hoses get hard? Is overheating on the gauge or is it actually boiling the water (you can hear it) and chucking steam out the expansion tank? It sounded like an airlock from the water pump change but that shouldnt still be the issue all this time later if it has had some use. Fans should kick in regardless, if they dont then sort that out first. The sensor might be in air and they dont kick in if still got air in it. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 17, 2019 Report Share Posted June 17, 2019 Also, take the cap off, rev the engine and look for increases in flow with rpm, tests water pump. Quote Link to comment Share on other sites More sharing options...
LR5V Posted June 17, 2019 Report Share Posted June 17, 2019 Mine was air locked and when it cleared it guzzled down at least 3 liters - probably more than 4 - of coolant, that was on top of what I thought was a reasonable amount. from the initial fill. Quote Link to comment Share on other sites More sharing options...
bg02gar Posted June 23, 2019 Author Report Share Posted June 23, 2019 Yeah does it on a run , obviously having the heaters on coils her down a bit which keeps me running , going to have a play this afternoon Quote Link to comment Share on other sites More sharing options...
