LynseyLou Posted July 11, 2013 Author Report Share Posted July 11, 2013 Do not use nonstopauto on Ebay for these kitsAbsolutely rubbish repro crap that isn't worth bothering with both locking rings snapped due to them being made of the cheapest thinnest metal known to mansteer clear Quote Link to comment Share on other sites More sharing options...
Skezza Posted July 11, 2013 Report Share Posted July 11, 2013 open a case against them me thinks. Quote Link to comment Share on other sites More sharing options...
LynseyLou Posted July 11, 2013 Author Report Share Posted July 11, 2013 (edited) well they didn't seem too bothered that both snappedand promised to refund straight away and didn't want the parts back ....Had to do away with the spring as it gave too much tension preventing the locking tabs to hold the paddle stiffdone away with the broken locking ring too and used a circlip which seems to have done the jobEverything works Edited July 11, 2013 by LynseyLou Quote Link to comment Share on other sites More sharing options...
lindylou Posted July 18, 2013 Report Share Posted July 18, 2013 (edited) i am just trying to do the same now got no lock for about six months justbought kit off eay from ideal car parts. but lets face it when its off ebay it is a gamble if it is of good quality. i have been fiddling and swearing for three days now trying to get the spring in properly and reassemble barrel i am on the verge of taking it to the garage this is something i try and avoid but i know even if i sort out the barrel fitting it back is a pain too cause of the ring that holds it tight in the door but may try your circlip idea. ho humlindylou Edited July 18, 2013 by lindylou Quote Link to comment Share on other sites More sharing options...
eastielawd Posted January 2, 2014 Report Share Posted January 2, 2014 I have the problem with the door locks on my lupo aswell but when i am trying to take the door lock out its just not budging help please I have threpair kit at hand just cant get the thing off Quote Link to comment Share on other sites More sharing options...
GeoffD Posted January 2, 2014 Report Share Posted January 2, 2014 people! all you need to do is get yourselves a copy of vw elsawin. discs from ebay from about £6. tells you the complete lock procedure and everything else you need to know about your car. really, it's not worth me trying to explain it for six quid as , apparently I am now the lock guru! if you still get properly stuck then pm me, I won't bite. geoff Quote Link to comment Share on other sites More sharing options...
Bigplum Posted January 4, 2014 Report Share Posted January 4, 2014 (edited) It's a fiddle but do-able , but check your parts , the paddle lengths are different whilst some the kits do not take that into account.There are some YouTube guides if you search vw locks ,It really helps to have a vice as a fair bit of tension is needed to put it back together.I used a spare old key in the vice to hold the barrel vertical , then you may need a third hand to help to slide the collar in Edited January 4, 2014 by Bigplum Quote Link to comment Share on other sites More sharing options...
Bigplum Posted January 4, 2014 Report Share Posted January 4, 2014 YouTube video, shows the older polo lock but the idea is the same http://m.youtube.com/watch?v=lirCTsXw3CQ&desktop_uri=%2Fwatch%3Fv%3DlirCTsXw3CQ Quote Link to comment Share on other sites More sharing options...
