lupokp Posted May 30, 2013 Report Share Posted May 30, 2013 Basically my mate has water in the drivers footwell and behind in the rear footwell and we both have no idea where it could have come from, any ideas to get this sorted? Quote Link to comment Share on other sites More sharing options...
coopersim Posted May 30, 2013 Report Share Posted May 30, 2013 Blocked scuttle drains then getting in through the fan housing or possibly blocked sunroof drain tubes if applicable or possibly missing door membranes. Might be an idea to run some water around the suspect areas. Be warned that the ecu is in the scuttle! 1 Quote Link to comment Share on other sites More sharing options...
lupokp Posted May 30, 2013 Author Report Share Posted May 30, 2013 Just checked the scuttle drain and the drivers side was blocked and the level of water was quite high Ive unblocked it and the water drained out. And we have drained the footwell with a sponge. Thanks Quote Link to comment Share on other sites More sharing options...
coopersim Posted May 30, 2013 Report Share Posted May 30, 2013 Glad it's sorted! You might want to take off the leaf guard over the fan intake as there is a water sump at the bottom that may also be full of water, you should be able to reach in with a sponge and soak up the excess water. Quote Link to comment Share on other sites More sharing options...
