oil problem
My oil light keeps coming on,then going out and coming on again a few minutes later, but then doesn't come on again for ages. And before anyone asks, yes I have checked the oil,its fine.any ideas?
First thing I'd say is stop driving it for the moment. If it's your oil pressure dropping, you will quickly **** up your engine and seize it up.
Might be your bearings.
im not sure if its anything that serious, cos its done a fair few miles since it started coming on
It takes a bit more than a few miles to properly seize an engine, unless the thing is bone dry. Most modern cars can run with well under the dipsticks lowest measure. I still wouldn't recommend it though.
You might want to get the codes checked out, asap!
