antere07 Posted May 2, 2013 Report Share Posted May 2, 2013 Right so i bought that stuff cause you know £25 is a bargin an will do me for now.AnywayIve wired it all in sweet as a nut took less time than i thought tbh, i started at about 3:30 this afternoon and all the wiring was in by 5:30 at the latest so it just left me to wire it into the amp and then on to the sub.So i wired it all in and it wasnt working but i had a bad ground so i just put it on the boot catch just for like to make sure it worked like and it all worked fine. Then i decided to move it around abit and now its not working.The amp has power to it but the protector light is on, this happened when i had the bad ground but now if i use the ground i did before it still doesnt work any ideas? Quote Link to comment Share on other sites More sharing options...
antere07 Posted May 4, 2013 Author Report Share Posted May 4, 2013 Anyone? Quote Link to comment Share on other sites More sharing options...
Jason_lupo22 Posted May 4, 2013 Report Share Posted May 4, 2013 Is your earth wire hooked onto anything thats been painted? or is it still on the boot latch? Quote Link to comment Share on other sites More sharing options...
antere07 Posted May 4, 2013 Author Report Share Posted May 4, 2013 Its ok ive sorted it i re wired the amp and improved connections and done a new earth and its sorted now Quote Link to comment Share on other sites More sharing options...
