davie18 Posted April 26, 2013 Report Share Posted April 26, 2013 You can hear it in this video:http://www.youtube.com/watch?v=YGuk31fsPuY&feature=youtu.beAny ideas at all on what it is? I'm clueless, and don't seem to have worked out a pattern on when it occurs. It just seems to happen randomly, whether I'm on the power or off it, but usually only seems to happen at over 40mph or so. Quote Link to comment Share on other sites More sharing options...
davie18 Posted April 26, 2013 Author Report Share Posted April 26, 2013 Hmm the above video link isn't working now when I try it. This one should work though:http://www.youtube.com/watch?v=YGuk31fsPuY Quote Link to comment Share on other sites More sharing options...
davie18 Posted April 27, 2013 Author Report Share Posted April 27, 2013 I actually have an arosa but I thought this may well have happened on some Lupos too, so someone here might know the answer. Basically very often when I'm driving a sort of whistling sound randomly starts and stops when I'm moving, as can he heard in this video:http://www.youtube.com/watch?v=YGuk31fsPuY&feature=player_embeddedAny ideas as to what it could be? Quote Link to comment Share on other sites More sharing options...
low_slow_arosa Posted April 27, 2013 Report Share Posted April 27, 2013 go to a mechanic Quote Link to comment Share on other sites More sharing options...
Pete Posted April 27, 2013 Report Share Posted April 27, 2013 Great first post. Ass. Can you determine whether the noise is from inside the car or does it sound muffled like its coming from the engine area? It's hard to tell in the vid, could possibly even be wind noise from door seals or window seals. Quote Link to comment Share on other sites More sharing options...
m1cr08472 Posted April 27, 2013 Report Share Posted April 27, 2013 It's probably the fan on the radiator, spray some wd40 in it. Quote Link to comment Share on other sites More sharing options...
Pete91 Posted April 27, 2013 Report Share Posted April 27, 2013 go to a mechaniclol what's the point of going on a forum to give responses like that? Quote Link to comment Share on other sites More sharing options...
Silver! Posted April 27, 2013 Report Share Posted April 27, 2013 He's maybe a mechanic trying to protect his trade. Quote Link to comment Share on other sites More sharing options...
davie18 Posted April 27, 2013 Author Report Share Posted April 27, 2013 It's probably the fan on the radiator, spray some wd40 in it.Thanks I'll give that a try to see if it fixed it at all.Great first post. Ass. Can you determine whether the noise is from inside the car or does it sound muffled like its coming from the engine area? It's hard to tell in the vid, could possibly even be wind noise from door seals or window seals.Well it's not my first post, but yeah sorry about that. The video in the OP wasn't working for me when I checked it again which is why I posted the video with the normal youtube url the second time as I thought that would fix it, but now the first video is working anyway. And then I posted it in the lupo forum too, but I'm guessing that's not allowed seeing as that thread just got merged with this one, I don't see why it wasn't just deleted instead but meh. It sounds to me that it's more inside the car as opposed to being muffled. And yeah I've though it might be some sort of wind noise, but I just can't figure out in particular what would be causing it. I was just hoping someone on here would have had the same problem previously so they'd know what it was. Quote Link to comment Share on other sites More sharing options...
Pete91 Posted April 27, 2013 Report Share Posted April 27, 2013 I think Pete was referring to low_slow_arosa's comment 2 Quote Link to comment Share on other sites More sharing options...
Silver! Posted April 27, 2013 Report Share Posted April 27, 2013 ^^ Me too. Quote Link to comment Share on other sites More sharing options...
Pete Posted April 27, 2013 Report Share Posted April 27, 2013 ^^Me three. Quote Link to comment Share on other sites More sharing options...
n7yr Posted April 27, 2013 Report Share Posted April 27, 2013 drive with your windows open for a while, see if the whistling still occurs. if it doesat least you know its not the window seals. Quote Link to comment Share on other sites More sharing options...
Pete91 Posted April 27, 2013 Report Share Posted April 27, 2013 drive with your windows open for a while, see if the whistling still occurs. if it doesat least you know its not the window seals. Me four Quote Link to comment Share on other sites More sharing options...
davie18 Posted April 27, 2013 Author Report Share Posted April 27, 2013 Ok yeah I think Pete was referring to low_slow_arosa's commentHaha silly me. Quote Link to comment Share on other sites More sharing options...
magnumleigh Posted May 3, 2013 Report Share Posted May 3, 2013 I get that exact noise too! Been going on for years and I still haven't figured it out ...... It's very sporadic. I now just use it as a gauge that everything's working as it normally does Quote Link to comment Share on other sites More sharing options...
parna86arosa Posted May 5, 2013 Report Share Posted May 5, 2013 Try checking your brake vaccum line its a plastic pipe running behind your engine mine did this and there was a hole in it leaking preassure Quote Link to comment Share on other sites More sharing options...
