bjones07356 Posted March 30, 2013 Report Share Posted March 30, 2013 Hi all Picked my 58 plate fox 1.2 today, but as it was sunny and at 10 on the morning I didn't mention anythink about the lights, it seems that I know where the lights switch is and lights come on but none of the dash or lights to the stero comes on is there a special button or is t there any lights lol 1 Quote Link to comment Share on other sites More sharing options...
Silver! Posted March 30, 2013 Report Share Posted March 30, 2013 There may be a dimmer, but it should still give some light even at the dimmest.Could be a fuse; check your handbook, but I would call the seller.R Quote Link to comment Share on other sites More sharing options...
bjones07356 Posted March 30, 2013 Author Report Share Posted March 30, 2013 Okay thanks for the quick reply there seems to be a light with the symbols when first turn the key and the speedo red light is on but nothing else wired Quote Link to comment Share on other sites More sharing options...
Silver! Posted March 30, 2013 Report Share Posted March 30, 2013 On all my VWs there is a dimmer switch to the right of the steering wheel alongside the headlamp adjuster.But I reckon it's a fuse. Quote Link to comment Share on other sites More sharing options...
Silver! Posted March 30, 2013 Report Share Posted March 30, 2013 1 - SC1 - Fuse 1 on fuse holder C2 - SC2 - Fuse 2 in fuse holder C 5A - J393 - Convenience system central control unit 86s- J519-Onboard power supply control unit- K - Dash panel insert- R-Radio3 - SC3 - Fuse 3 on fuse holder C - 15a4 - SC4 - Fuse 4 in fuse holder C 5 A - E165 - Rear lid release switch 30a- F121 - Driver door exterior handle switch for anti-theft alarm system5 - SC5 - Fuse 5 in fuse holder C 20A - R - Radio 30a6 - SC6 - Fuse 6 in fuse holder C 20A - J48 - Heated rear window control relay XR7 - SC7 - Fuse 7 on fuse holder C8 - SC8 - Fuse 8 on fuse holder C - 9 - SC9 - Fuse 9 on fuse holder C - 10 - SC10 - Fuse 10 on fuse holder C - 11 - SC11 - Fuse 11 on fuse holder C - 12 - SC12 - Fuse 12 on fuse holder C - 13 - SC13 - Fuse 13 on fuse holder C - 14 - SC14 - Fuse 14 on fuse holder C 5A - E43 - Mirror adjustment switchE48 - Mirror adjustment change-over switchE165 - Rear lid release switchG516 - Potentiometer for horizontal adjustment of front passenger side mirrorG517 - Potentiometer for vertical adjustment of front passenger side mirrorJ267 - Mirror memory control unitJ393 - Convenience system central control unitL78 - Mirror adjustment switch illumination bulbV25 - Front passenger side mirror adjustment motorV150 - Front passenger side mirror adjustment motor 15a15 - SC15 - Fuse 15 on fuse holder C 25A - J365 - Air conditioning system switch-off relay 30a16 - SC16 - Fuse 16 on fuse holder C 25A - J393-Convenience system central control unit 30a17 - SC17 - Fuse 17 on fuse holder C 15A - E23 - Front and rear fog light switchL40 - Front and rear fog light switch illumination bulb 5518 - SC18 - Fuse 18 on fuse holder C 10A - V12 -Rear window wiper motor XR19 - SC19 - Fuse 19 on fuse holder C - 20 - SC20 - Fuse 20 on fuse holder C - 21 - SC21 - Fuse 21 on fuse holder C - 22 - SC22 - Fuse 22 on fuse holder C - 23 - SC23 - Fuse 23 on fuse holder C 5A - J104 -ABS control unit 15a24 - SC24 - Fuse 24 on fuse holder C - 25 - SB25 - Fuse 25 on fuse holder B 10A - E3 - Hazard warning light switch 15a26 - SB26 - Fuse 26 on fuse holder B 10A/ 25A - N152 - Ignition transformer 15a27 - SB27 - Fuse 27 on fuse holder B 15A/ 10A - J101 - Radiator fan 2nd speed relayJ209 - Fresh air blower and radiator fan relay 30a28 - SB28 - Fuse 28 on fuse holder B 5A - K - Dash panel insert 30a29 - SB29 - Fuse 29 on fuse holder B 15A - E22 - Intermittent wiper switchJ31 - Automatic intermittent wash and wipe relayV - Wiper motor 53a30 - SB30 - Fuse 30 on fuse holder B 5A - J623-Engine control unit 15a31 - SB31 - Fuse 31 on fuse holder B 5A - M2 - Right tail light bulbM3 - Front right side marker bulb 58r32 - SB32 - Fuse 32 on fuse holder B 5A - E3 - Hazard warning light switchJ301 - Air conditioning system control unitK - Dash panel insertL28 - Cigarette lighter illumination bulbL42 - Socket illumination bulbX - Number plate light 5833 - SB33 - Fuse 33 on fuse holder B 15A - G - Fuel gauge senderG6 - Fuel system pressurisation pump 87a34 - SB34 - Fuse 34 on fuse holder B 10A - J41 - Cold start device relayN80 - Activated charcoal filter solenoid valve 1 87a35 - SB35 - Fuse 35 on fuse holder B 10A/15A - K - Dash panel insertL1 - Left headlight twin filament bulb/left sealed beam insert 56al36 - SB36 - Fuse 36 on fuse holder B 10A - L1-Left headlight twin filament bulb/left sealed beam insert 56bl37 - SB37 - Fuse 37 on fuse holder B 10A - F4-Reversing light switch 15a38 - SB38 - Fuse 38 on fuse holder B 5A - E386 - Anti-dazzle interior mirror buttonF47 - Brake pedal switchF36 - Clutch pedal switchJ17 - Fuel pump relayJ362 - Immobilizer control unitJ365 - Air conditioning system switch-off relayK - Dash panel insertK187 - Anti-dazzle interior mirror warming lampY7 - Automatic anti-dazzle interior mirror 15a39 - SB39 - Fuse 39 on fuse holder B 10A - J267 - Mirror memory control unitJ519 - Onboard supply control unitW1 - Front interior lightW3 - Luggage compartment light 30a40 - SB40 - Fuse 40 on fuse holder B 10A - F -Brake light switch 15a41 - SB41 - Fuse 41 on fuse holder B 10A - H1 - Horn or dual tone hornJ4 - Dual tone horn relay 15a42 - SB42 - Fuse 42 on fuse holder B 25A - E9-Fresh air blower switchJ301-Air conditioning system control unitV154-Fresh air and air recirculation flap control motor XR43 - SB43 - Fuse 43 on fuse holder B 5A - E1 - Light switchE4 - Headlight dipper and flasher switch 58l44 - SB44 - Fuse 44 on fuse holder B 10A/ 5A - N30-Injector, cylinder 1N31-Injector, cylinder 2N32-Injector, cylinder 3N33-Injector, cylinder 4 87a45 - SB45 - Fuse 45 on fuse holder B 10A/ 30A - G39 - Lambda probe 87a46 - SB46 - Fuse 46 on fuse holder B 10A/ 15A - L2-Right headlight twin filament bulb 56ar47 - SB47 - Fuse 47 on fuse holder B 10A - L2-Right headlight twin filament bulb 56br48 - SB48 - Fuse 48 on fuse holder B 20A - J59 - X-contact relief relay XR Quote Link to comment Share on other sites More sharing options...
bjones07356 Posted March 30, 2013 Author Report Share Posted March 30, 2013 Do you now what number fuse it is Quote Link to comment Share on other sites More sharing options...
Silver! Posted March 30, 2013 Report Share Posted March 30, 2013 I Would start with any that mention "dash" or "switch".R Quote Link to comment Share on other sites More sharing options...
Silver! Posted March 30, 2013 Report Share Posted March 30, 2013 Could also be the dimmer switch is faulty. Quote Link to comment Share on other sites More sharing options...
