GTi mpg
davidelliott294
If you're having a good time it's smiles per gallon and you shouldn't worry about it.
Do a tank conservatively and then report back.
Been having an awesome time..
I filled it again earlier, got £38 in (not including removing the air).
I will try drive like a granny.
Not worried about MPG, just want to make sure it ain't running rich and should.be getting more miles for the same sort of smiles :)
If you're driving it properly at high speeds accelerating through the revs and generally bouncing it about a bit then 170 is about right.
Sometimes it is good to try to get a decent amount out of the tank just to know that things are running right.
+1, not sure if your engine has them but maf's and lambda's arent always flagged up by the CEL.
I get between 170 and 215 per tank on momentum or v power, all depends on if its motorway or around town
Yeah sounds about right to me, i get about 180 to a tank when giving it stick. Although i have got as little as 140 to a tank on one occasion when spending a day driving my favorite roads. Then again when being sensible i have got about 240. Always using v-power by the way.
Mike
Edited by Thissy
Yeah think it's pump related lol about 170 needs nanagment to get the most out of it after a omex 600
Is there something wrong with it?
What power are to putting out?
Not sure yet, taking it easy to see how many miles I get to a tank then deciding :)
Standard power but I wasn't exactly taking it easy on my last tank of fuel, was having quite a bit of fun tbh.
