angelo77 Posted March 6, 2013 Report Share Posted March 6, 2013 Will find out tomorrow if these fit with the spacers I have had made, Could be tears but hopefully joy Et of 38 plus a 12 mm spacer gives me an increase of 24mm aprox with 13mm less insidw the arch, Anyone running the above offset with a 25mm spacer on the rear? Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted March 7, 2013 Report Share Posted March 7, 2013 Im not sure you are working this out correct.Original width might help decide if the wheels will fit inside the arches, plus the tyre choice.But if they are ET38 then a spacer of 12mm will in my basic basic finger and toes maths method make them ET26.The easiest method of checking for scrubbage is to measure........ with a tape or rule. Quote Link to comment Share on other sites More sharing options...
angelo77 Posted March 7, 2013 Author Report Share Posted March 7, 2013 Hi pal, fitted on a treat with 4 mm of clearance spacers and offset bring them flush with the arch with approximate 40mm of reduction in ride hight.Just need the sun to shine to take some pictures Quote Link to comment Share on other sites More sharing options...
