Skezza Posted February 26, 2013 Report Share Posted February 26, 2013 (edited) Has anyone fitted these?:http://www.ebay.co.uk/itm/2-Car-H4-120-SMD-LED-Head-Light-Headlight-Bulb-Lamp-12V-/271082717702?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f1dca0206andhttp://www.ebay.co.uk/itm/2X-LED-BULB-CAR-LIGHT-WHITE-13-18-SMD-High-Power-Headlight-Fog-Light-/190679862798?pt=UK_Light_Bulbs&var=&hash=item2c6567ce0eInstead of using bulbs.You can get them in H4 and H7 so you could have them for both dipped and beam.Thoughts... Edited February 26, 2013 by Skezza Quote Link to comment Share on other sites More sharing options...
jakeyg Posted February 26, 2013 Report Share Posted February 26, 2013 Says not to be used as headlight in the listing tho Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 26, 2013 Report Share Posted February 26, 2013 Would work in projector style headlights, i wouldn't bother on std lupo lights though. Would look like fairy lights. Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 26, 2013 Author Report Share Posted February 26, 2013 Says not to be used as headlight in the listing thoNo, the side light one does, the one with a load more LED's says can be used as headlight. Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 26, 2013 Report Share Posted February 26, 2013 Theyre not road legal. Quote Link to comment Share on other sites More sharing options...
matt123roll Posted February 26, 2013 Report Share Posted February 26, 2013 I'll save you the hassle and just tell you they have a shocking light output and be terrible. 1 Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 26, 2013 Report Share Posted February 26, 2013 If its a nice white colour you want, go for phillips diamond vision H4 (note, these aren't technically road legal either, but i've never had any issues.) If its power, osram nightbreakers. Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 26, 2013 Author Report Share Posted February 26, 2013 I'll save you the hassle and just tell you they have a shocking light output and be terrible.Ahh fair enough. I'll save myself the bother then. Replacement bulbs from the rear can be got in LED, and I've seen them, they look quite good, but with front lights being such a pig to change, LED's sounded perfect. I might give them a miss then.To be honest Joe, it was neither colour nor brightness, it was longevity, LED's can last for ages. However I might go for the Philips blue ones as they're quite fashionable too. Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 26, 2013 Report Share Posted February 26, 2013 Yeah go for diamond vision, they are bluey white, if you go for the actual blue ones, the fuzz will have you. Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 26, 2013 Author Report Share Posted February 26, 2013 (edited) Yeah go for diamond vision, they are bluey white, if you go for the actual blue ones, the fuzz will have you.Got ya, will go for the Diamond Vision then. I think this thread should be written off to be honest, I certainly don't want anyone to buy those LED bulbs I linked up there.After I did a bit of research and read up on a bit, I realized you will never get them through an MOT, and also, I imagine they are dangerously dark.They give out a maximum of 450 Lumens and according to my mate who works at a test centre, a standard Lupo with standard headlights will fail it's MOT if it isn't giving out a minimum of 1000 Lumens.Although I assume they don't measure it, just do it by visual.So yep, **** that. Edited February 26, 2013 by Skezza Quote Link to comment Share on other sites More sharing options...
