jmakari Posted February 20, 2013 Report Share Posted February 20, 2013 I have just installed a air induction kit on my lupo and there are 3 pipes left uncapped. I think they are called oil breathers and have very little use but to reduce pollution.Is there anyway of capping them because I've heard oil vapour comes out of them aswell as carbon monoxide?Also I've heard a catch tank can be used and filters to reduce pollution. Any ideas??? Quote Link to comment Share on other sites More sharing options...
m1cr08472 Posted February 20, 2013 Report Share Posted February 20, 2013 I don't think capping them off would be a good idea. If your engine can't breath out of the pipes it will breath out of somewhere else, probably your cylinders increasing emissions. Could mean an mot failure. I'd go with the catch tank idea. I wouldn't leave them just hanging loose either cause if any oil leaks onto a hot engine it could cause a fire. Quote Link to comment Share on other sites More sharing options...
jmakari Posted February 20, 2013 Author Report Share Posted February 20, 2013 Thanks m1cr08472. You are right engine oil burns around 400 degrees and engine temperature can rise that high.Any ideas what to do with the other two pipes?? Quote Link to comment Share on other sites More sharing options...
Pete91 Posted February 21, 2013 Report Share Posted February 21, 2013 Just plumb them to the catch tank and then from tr catch tank to the TB Quote Link to comment Share on other sites More sharing options...
