moreno510 Posted December 2, 2003 Report Share Posted December 2, 2003 since i got my tyres changed ive noticed some steering wheel vibration at about 60 - 70 mph its not the balancing , any suggestions ??? Quote Link to comment Share on other sites More sharing options...
twisty b-road Posted December 2, 2003 Report Share Posted December 2, 2003 Every car I've had (except the one I got now) that was still wearing it's original tyres when I bought it has never had satisfactory replacements. Maybe the manufacturers do something special at the factory. Does the factory balance the drive shafts? You got SP8000 didn't you? They're directional, are the arrows on the tyres pointing the right way? (stupid suggestion?)Is it a dodgy tyre? Can you jack the car up and spin the wheels to check you have straight treads? Quote Link to comment Share on other sites More sharing options...
i99y Posted December 2, 2003 Report Share Posted December 2, 2003 happened to me but took it back to the garage and one the weights had fallen off! the garage replaced the weight and the problem was sorted! Quote Link to comment Share on other sites More sharing options...
moreno510 Posted December 2, 2003 Author Report Share Posted December 2, 2003 already been back in and had the balance checked , no probs , i'll try checkin the tyre but after that feek knows Quote Link to comment Share on other sites More sharing options...
twisty b-road Posted December 2, 2003 Report Share Posted December 2, 2003 Have you tried swapping front for back one side at a time to see if it's one of the fronts? Quote Link to comment Share on other sites More sharing options...
Lynsey Posted December 2, 2003 Report Share Posted December 2, 2003 QUOTE(i99y)happened to me but took it back to the garage and one the weights had fallen off! the garage replaced the weight and the problem was sorted!Ok this is gonna sound real dumb, but are you meant to have weights on all of the wheels? Coz when i had my rear tyres done last week, I've noticed since that I no longer have weights on them ??? You can see where they were before but now they ain't there *CONFUSED*Should I have them or not? style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" /> Coz I know when they did the tyres, they were balanced and stuff but I'm abit of a "duh" when it comes to technical stuff so help appreciated :thumbs: Quote Link to comment Share on other sites More sharing options...
RobinA3 Posted December 2, 2003 Report Share Posted December 2, 2003 L they might have stuck the weights on the inside of the wheels. Quote Link to comment Share on other sites More sharing options...
Crusoe Posted December 3, 2003 Report Share Posted December 3, 2003 If they do a good job (or you ask specially) they should use the flat weights that go inside the back of the rim which don't fall off as easily and are hidden form the outside. Would have said it sounded like a weight falling off but if it's not the balance the next likely thing would be if they tyres were put on in the right direction (and side if they are fully directional tyres) and that it isn't a dodgy tyre with a bulge. Once took one off a mate's car after it had new tyres fitted and was reporting similar symptoms. It looked fine when it was on the car but taking it off and rolling the wheel on it's own the tyre was egg shaped with a huge bulge at the top. Might need to take the top mechanic out for a drive and show him to prove something's wrong. Quote Link to comment Share on other sites More sharing options...
moreno510 Posted December 23, 2003 Author Report Share Posted December 23, 2003 swapped my passenger side front and back tyres about today and noticed it seems to have stopped the vibrationhave to have a wee chat with 'the boys to trust' tomorrowwhats the betting it wasnt their fault ? Quote Link to comment Share on other sites More sharing options...
RallyeBaz Posted December 23, 2003 Report Share Posted December 23, 2003 I had the problem with my aftermarket dished alloys. But solved most of the problem with plastic sprogetts on the hubs. It will only be perfect if I have weights on the polished rim Quote Link to comment Share on other sites More sharing options...
