lupomadness Posted December 17, 2012 Report Share Posted December 17, 2012 when i hit the break i can hear a rubbery squeek mite be a squeeky suspension spring but am not a mechanic or mechanicaly skilled any ideas in what this could be.. thanks : ) Quote Link to comment Share on other sites More sharing options...
lupomadness Posted December 18, 2012 Author Report Share Posted December 18, 2012 i ment when u break hard and the car dips forward thers a rubbery squeek could it be s shock absorber or somthing Quote Link to comment Share on other sites More sharing options...
m1cr08472 Posted December 18, 2012 Report Share Posted December 18, 2012 Could be anything, I'd either turn the radio up and forget about it or take it to a garage and get it serviced. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted December 18, 2012 Report Share Posted December 18, 2012 Sure it's not actually coming from the brakes? Quote Link to comment Share on other sites More sharing options...
lupomadness Posted December 18, 2012 Author Report Share Posted December 18, 2012 defo not the breaks had it on the ramps at kwikfit today had front n back breaks checked also had suspension checked but forgot to ask about the absorber.. if it is the shocky does anybody know how much to fix it .. could it be the top bolt that holds the suspension in place ? Quote Link to comment Share on other sites More sharing options...
Paul T Posted January 4, 2013 Report Share Posted January 4, 2013 If you press down hard on the front of the car at both sides does the car return back equally, is one side more wallowy than the other? Check the dampers are dry and not leaking and the springs are complete and not cracked. Could be a suspension top mount as well, whichever one it is mate they are not expensive repairs. Quote Link to comment Share on other sites More sharing options...
