Epick Posted December 4, 2012 Report Share Posted December 4, 2012 Hey all, I just purchased http://www.amazon.co.uk/Seat-Car-Mudflaps-Ibiza-Toledo/dp/B002WV0XHA/ref=sr_1_1?ie=UTF8&qid=1354658703&sr=8-1 The only way I can see to fit them is too remove the rear wheels and create holes in the rear bumper so they fit. Has anyone else done this before? Cheers Quote Link to comment Share on other sites More sharing options...
TArosa Posted December 5, 2012 Report Share Posted December 5, 2012 Not sure if they are the same as the lupo fitment. But if the are, it would help to have the wheels off and the inner arch / carpet screws are what's used to secure hem on, test fit and see if they line up Quote Link to comment Share on other sites More sharing options...
lupo1.0se Posted December 5, 2012 Report Share Posted December 5, 2012 There is a way with out taking the wheels out.You need a pair of molegrips and screw driver torx headAttach the head to the molegrips and this should get round your problem. Quote Link to comment Share on other sites More sharing options...
mattarosa Posted December 5, 2012 Report Share Posted December 5, 2012 failing that use a socket set... wont knacker your driver bit that way 1 Quote Link to comment Share on other sites More sharing options...
JoeA Posted December 5, 2012 Report Share Posted December 5, 2012 OR a 90 degree ratchet?! 1 Quote Link to comment Share on other sites More sharing options...
Epick Posted December 5, 2012 Author Report Share Posted December 5, 2012 Cheers all, I tried your ideas and it will screw into the existing holes behind the tyre but I can't find a hole for the bottom right of the mudflap to fit onto. So it will just swing around and I'll look like a prat aha Quote Link to comment Share on other sites More sharing options...
Tobs23 Posted December 5, 2012 Report Share Posted December 5, 2012 i just took the wheels off to do mine, only 4 bolts lol, then i drilled new holes in the liner and used the screws provided to secure the mud flaps, if your puting front ones on like mine then all you need to do is put the steering on full lock Quote Link to comment Share on other sites More sharing options...
Pete91 Posted December 5, 2012 Report Share Posted December 5, 2012 So it will just swing around and I'll look like a prat ahaJust drill a hole? 1 Quote Link to comment Share on other sites More sharing options...
Epick Posted December 6, 2012 Author Report Share Posted December 6, 2012 Yeah just removed the wheels and arch trim and screwed it in. Looks pretty good I'll upload a picture asap Quote Link to comment Share on other sites More sharing options...
Koop Posted December 7, 2012 Report Share Posted December 7, 2012 hurhurhur...flaps 1 Quote Link to comment Share on other sites More sharing options...
mattarosa Posted December 7, 2012 Report Share Posted December 7, 2012 ^ screwing flaps koop... 1 Quote Link to comment Share on other sites More sharing options...
Epick Posted December 7, 2012 Author Report Share Posted December 7, 2012 Sorry for the awful quality! Quote Link to comment Share on other sites More sharing options...
mattarosa Posted December 9, 2012 Report Share Posted December 9, 2012 looking good... i think you're right to stick with the arosa rears with it being red Quote Link to comment Share on other sites More sharing options...
