Lowerthangavin Posted November 26, 2012 Report Share Posted November 26, 2012 Right, so I've browsed previous threads on here about this issue of the heater blower not working, most people seem the replace the resistor and problem solved, however I've replaced my resistor (it was corroded) yet the blower system still doesn't work on any speed or temp.. Is the next step to replace the blower motor itself or is there another thing that could be causing this? Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 26, 2012 Report Share Posted November 26, 2012 test the blower itself, just find the plug for it and add power from the battery to it directly, that will save u time and hassle of removing the dash to change it if its not the fault Quote Link to comment Share on other sites More sharing options...
Lowerthangavin Posted November 26, 2012 Author Report Share Posted November 26, 2012 Ah that's such a good idea, cheers man Quote Link to comment Share on other sites More sharing options...
Ironflitz Posted November 26, 2012 Report Share Posted November 26, 2012 Check the fuse for short circuit (blown fuse).Do what Adzer suggested - if the motor spins, fandabbydosey.If the motor doesn't spin, buy a new one.If the motor does spin, but doesn't blow any air at all, check the switches behind the dash for loose connections.I notice you have done the 'resistor fix', check all the resistors within the resistor pack.If none of these work, wear a ski jacket, ski mask, ski gloves, ski socks, 3 pairs of thermal trousers, 8 t-shirts and four beenies.Obviously, if it is hot, drive naked with the windows down and purchase an in-car fan (or 5).Nath. Quote Link to comment Share on other sites More sharing options...
Lowerthangavin Posted November 26, 2012 Author Report Share Posted November 26, 2012 Hahahaha, cheers Nath, i'll be doing these tomorrow. Thanks a lot Quote Link to comment Share on other sites More sharing options...
Ironflitz Posted November 26, 2012 Report Share Posted November 26, 2012 No probs Gav. Quote Link to comment Share on other sites More sharing options...
