Brake/ABS Issue
sportrider-si
Yeah when i was putting shims on mine i forgot to stick the plug back in and the light came on.
Did you get the abs intruding when you did this? the abs intrusion is making it difficult to drive, as the stopping distance in significantly increased in its current state. It only does short journeys so no abs for a couple of days will be fine.
I'd imagine disconnecting the sensor although bringing the light on wouldn't cause the fault you're getting at the minute to occur as you wouldn't be getting any readings at all from the wheel, instead of a faulty one.
Unplugged the abs sensor yesterday, The end of the sensor is smashed to bits. I now have another problem, because I'm an idiot I forgot to measure the one standard bolt that was left in the wheel. Does anyone know the length of the standard bolts? As these are now on show gonna get some nice looking ones instead of rusty crappy ones. Help?
  • 1 month later...
