Adzer Posted November 11, 2012 Report Share Posted November 11, 2012 well guys i'm new to this forum and thot i would share my latest project with you guys, i bought this car from a member off here 3 weeks ago with only one intention for it...........1.8t track slagthis car is just gonna be a toy car and a sideline project along side my other project car (4wd leon cupra r 425bhp+)anyway ill copy and paste my progress so far from the local forum i use, hope you guys enjoyDrove down to Bradford to pick it up.Bought it for 500 which I think was cheap for what i got.Debaged grillFlushed bonnetBonnet braTsw alloysGti rear bumperCat back exhaustCoiloversClifford alarm and immobOrange roof and mirrorsOrange interior panelsJvc headunitEngine is rough, gearbox is shagged and had no seats or door cards as they was retrimmed orange leather and was worth a pretty penny alone.Any way some pics Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 11, 2012 Author Report Share Posted November 11, 2012 The wheels are just awful and are going once I find a better set.Well since I got home from england all I've done is sleep as I was shattered, woke up today feeling a bit more refreshed, as I'm still unsure exactly what my plans for the car are there isn't much I can doBut I'm not the kinda guy that can just sit and do nothing.......as the cars soooo small and I'm a lanky **** there was no point buying rear seats so I'll just put in bucket seats in the front which means I don't need the rear trim ;-) Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 11, 2012 Author Report Share Posted November 11, 2012 Some tasty updates for you lucky buggers today, ordered a set of bucket seats yesterday and they came today ;-)Also bought this for the Leon build but will look better in the lupo for now Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 11, 2012 Author Report Share Posted November 11, 2012 These should also do the trick along with the seats Quote Link to comment Share on other sites More sharing options...
joshuaar Posted November 11, 2012 Report Share Posted November 11, 2012 welcome dude, nice start so far.seems to be a few on here with the orange and black theme at the minute, and with good reason as it looks sweet.how far are you taking the stripping of the interior? Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 11, 2012 Author Report Share Posted November 11, 2012 Well I'm off work this week so the project has started, my plan is to get the old engine out and prep for the new engine.Started off removing front endNow to prep up the bay.......Aircon is for gays Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 11, 2012 Author Report Share Posted November 11, 2012 Before I start fabricating engine mounts I need to sort out the pedals as the lupo was clutch cable and the 1.8t Is hydraulic!To do this the dash needed to come out :-(While dash was out I removed the airbag and these are also for gaysOriginally the 3 pedals went thru the pedal box with one bolt but the new clutch pedal is completely different so I had to mod the lupo pedal box and chop some brackets offThis is the new clutch pedalNext problem was I was left with a hole in the bulkhead where the original clutch cable came thru. Most ppl would say just leave it but problem being one of the pedal mounting holes sits right where the hole is lolSo out with the welder to fill the holeOnce that was welded up I just needed to mount the pedal, I had to fabricate a bolt to come thru the bulkhead. Its a but long so will get the grinder on it tomorrowSo at the end of the day engines out, and pedal box is finishedTomorrow remove 1.8t from donor car ;-) Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 11, 2012 Author Report Share Posted November 11, 2012 Well thot I'd post a update while I eat my lunch, to finish off the pedal box I had to try make the throttle cable from the donor car fit the lupo. Turned out to work out pretty well. All I had to do was remove a plastic clip and it fitted straight on :-)Next job was the gear linkage, lupo has linkages where as donor engine uses cables, once I removed both and compared side by side there was a fair difference in size and the way they mount to the car, after a bit of thinking a found the solution I had to cut of some brackets on the chassisOnce that was removed I offered up theNew linkage box to see where I'd need to drill holes to mount it, once I had the holes drilled I tried to fit the shifter to find that the bolts was too short, so I had to cut the original bolts off as the was captive bolts, and weld some longer ones in place so it was long enuf to come they the floor on the inside, some pics of thisOnce that was done u could put the dash back in placeAlso started removing the sound deadening, what a cock of a job Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 11, 2012 Author Report Share Posted November 11, 2012 To answer your question Cammy I'm thinkng of making my own loom as I just purchased this and will eliminate half the wiresAnd these also arrived so now I can mount some seats Quote Link to comment Share on other sites More sharing options...
MiiTCH-TDi Posted November 11, 2012 Report Share Posted November 11, 2012 Sweet Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 11, 2012 Author Report Share Posted November 11, 2012 Bit more progress was madeYesterday, started to cut back the loom of the wires I wouldn't needThen started to work on mounting the engine, the driver Side mount needed to be cut out and replaced with the one from the a3, but the a3 mount needed cut to fitOriginal mountEngine lifted into place to measure up for the passenger side mount Quote Link to comment Share on other sites More sharing options...
Sp3nny Posted November 11, 2012 Report Share Posted November 11, 2012 straight in with the work then fella! your right those wheels were f***ing awful, but those bucket seats look quality and fit in nice with the colour scheme. Can't wait to see the end product, weird to see something i used to own stripped apart Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 11, 2012 Author Report Share Posted November 11, 2012 Well spent about 4 hours tryin to get this engine mounted and was ready to loose the plot, eventually got a mount made up for the passenger side but still having some Clearance issues with gearbox/subframe, nowt my hammer won't solve ;-)Anyway here's some picsHad to chop chassis leg :-/Engine mounted without hoist ;-)Bonnet closes.....JUST Quote Link to comment Share on other sites More sharing options...
Piers Posted November 11, 2012 Report Share Posted November 11, 2012 Cracked on with that! Mint Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 11, 2012 Author Report Share Posted November 11, 2012 Latest edition for the car ;-)New edition to my BUILDWas hoping to have the engine mounted for good today but didn't happen, got a few bits done none the less.Got the bay paintedGot my home made mounts painted tooBefore the engine goes in I wanted to change the clutch, so I bought a solid flywheel conversion kit to get rid of the dual mass flywheelBox offOld clutchNew clutch Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 11, 2012 Author Report Share Posted November 11, 2012 thanks for the comments guyshopefully get the engine mounted tomorrow for the last time Quote Link to comment Share on other sites More sharing options...
Joti Posted November 11, 2012 Report Share Posted November 11, 2012 (edited) Aircon is for gaysWhile dash was out I removed the airbag and these are also for gaysWow, you learn something every day......... - I never realised gay people were so safety conscious (or maybe they're just bad drivers?!)! Edited November 11, 2012 by Joti Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 11, 2012 Author Report Share Posted November 11, 2012 Wow, you learn something every day......... - I never realised gay people were so safety conscious (or maybe they're just bad drivers?!)! real men laugh in the face of danger Quote Link to comment Share on other sites More sharing options...
Fob163 Posted November 12, 2012 Report Share Posted November 12, 2012 interested to see how this turns out! cracking on with the conversion fast! Quote Link to comment Share on other sites More sharing options...
Ellzbmx Posted November 12, 2012 Report Share Posted November 12, 2012 Looks sick man! Quote Link to comment Share on other sites More sharing options...
Koop Posted November 12, 2012 Report Share Posted November 12, 2012 Loving the detailed progress pics keep up the good work Quote Link to comment Share on other sites More sharing options...
Adzer Posted November 12, 2012 Author Report Share Posted November 12, 2012 My leon build was a bit more in depth with the pics than this build :-)I'd like to think this thread will help ppl do this conversion Quote Link to comment Share on other sites More sharing options...
TheOwlTwooo Posted November 12, 2012 Report Share Posted November 12, 2012 This is amazing. Quote Link to comment Share on other sites More sharing options...
Koop Posted November 12, 2012 Report Share Posted November 12, 2012 I'd like to think this thread will help ppl do this conversion This is what i'm thinking. Quote Link to comment Share on other sites More sharing options...
JamesTdi Posted November 12, 2012 Report Share Posted November 12, 2012 Loving this mate, more details as you go along! Quote Link to comment Share on other sites More sharing options...
