1litrePWER Posted November 1, 2012 Report Share Posted November 1, 2012 Hi question i need a bit of help on , i have a amp and sub in a box and all the relevant cables Power remote earth and rca cables . I need to find out where i could run the power cable to the battery safley without drilling a hole ??? Quote Link to comment Share on other sites More sharing options...
James827 Posted November 1, 2012 Report Share Posted November 1, 2012 look for a place in the bulkhead where wires are already going in and go through that hole.. Quote Link to comment Share on other sites More sharing options...
TArosa Posted November 1, 2012 Report Share Posted November 1, 2012 pull the heather controls an glove boxs out ... feed it through where th interior loom comes through then through behind the glove box and down into foot well Quote Link to comment Share on other sites More sharing options...
Battsy Posted November 4, 2012 Report Share Posted November 4, 2012 Underneath your glove box should be a "cover" you can pull this downwards and it should reveal a couple of wires running from the head unit into the door speakers, Well from your bonnet if you look to where your glove box is you should see a little whole already there, i put mine through here and then pulled it from under the glove box then hid the wiring under the floor, pretty simple once you find the whole Quote Link to comment Share on other sites More sharing options...
Pete91 Posted November 4, 2012 Report Share Posted November 4, 2012 Underneath your glove box should be a "cover" you can pull this downwards and it should reveal a couple of wires running from the head unit into the door speakers, Well from your bonnet if you look to where your glove box is you should see a little whole already there, i put mine through here and then pulled it from under the glove box then hid the wiring under the floor, pretty simple once you find the wholeThis Quote Link to comment Share on other sites More sharing options...
