Members ICE install.
Photos and Specs Only Please.
A photo only is fine, but it would be good to answer all the common questions, in this post.
When writing specs, please include rms ratings of your amps, and any extra goodies you have helping it along.
If you have a link to your products on line post it and I'll make it look pretty for you if you don't know how.
I will host up to 2 photos for anyone without the use of anywhere.
Tigz
If it is possible could you please resize them to a maximum 800x600 so they will fit in the Page alright.
If you don't know how, I can do it, but I would love you more if I didn't have to :wink:
Please no Spam.
Drop me a pm if you have any comments/queries.
Discussion Thread please use this.
Edited by Tigz
  • 3 weeks later...
>Tshirt2k's ICE<
Clarion headunit DXZ848RMC
Infinity 65.5 Cs components in MDF mountings 90 WRMS
Crystal Comp 10 in Custom made 0.9 cuft sealed Fibreglass enclosure
Rockford fosgate P8004 amp 2 x 100 WRMS & 1 X 400 WRMS
Info on Rockford fosgate amp can be found Here
Edited by Tigz
  • Like 7
  • 4 weeks later...
Sony F7700 headunit (i know i know, shoot me)
4 Alpine Type S 5x7" Components, unfortunately powered by the headunit
1 Kenwood KAC-PS811D Amp giving 1 x 800rms at 2ohm
2 JL W3v2-D2 subs powered by the Kenwood amp
Dynamat Extreme on the boot floor and wheel arches
Dynamat Original surrounding each component
  • 1 year later...
Thought id add my ICE here, not a lupo but shows what can be done with a small amount of space-
JVC Headunit with iPod interface
4 Channel Rockford Fosgate Amp, giving Kenwood components 65wrms each and a JBL 8" sub 250wrms.
Flashing tape, eDead, Second Skin as sound deadening/proofing.
Still plenty of boot space left for stuff.
Edited by Tigz
  • 2 months later...
hi guy's got the gti on sunday, so set about mounting the sub and what not.
system:
vibe black hex 6.5 speakers
Specifications*
BlackHex 6
Type Co-axial
Configuration 2-way
Speaker Size 6.5" (165mm)
RMS Power 100w
Peak Power 300w
Sensitivity 87dB
Frequency
Response 40 - 25,000Hz
Impedance 4ohm
Mounting Depth 76mm
Mounting Diameter 140mm
these really thump, had these in my leon, and put them into my home cinemas speakers.
then the amp
vibe black box 1
Specifications*
BLACKBOX I
Height 50mm
Width 224mm
Depth 177mm
RMS Out @4ohm 2 x 70w
RMS Out @2ohm 2 x 100w
RMS Out @4ohm 1 x 200w
SNR 100dB
Frequency
Response 20 - 20,000Hz
THD 0.05%
Crossover Type LP/HP/Flat
Crossover Range 50 - 5,500Hz
Crossover Slope 12dB
Bass Enhance
(variable @ 45Hz) 18dB
Max Power 400W
kenwood 12" w3009 sub
Size 12 -inch
Impedance 4 ohms
Cone Material Pearl mica IMPP
Surround Material Urethane foam
Sealed Box Volume (cubic feet) 0.8 - 1.5
Ported Box Volume (cubic feet) 1 - 2
Port diameter (inches) 3
Port length (inches) 7
Sensitivity 93dB
Frequency Response 25 - 0.8k Hz
RMS Power Range (Watts) 35-400
Peak Power Handling (Watts) 800
Top Mount Depth (inches) 5 5/16
Bottom Mount Depth (inches) 6 1/8
Cutout Diameter or Length (inches) 11
Vas (liters) 63.93
Fs (Hz) 32
Qts 0.42
Xmax (millimeters) 8
Parts Warranty 1 Year
Labor Warranty 1 Year
cross over just to run the sub gives more tuning, cant remember the make.
head unit sony cdx-ra650 because it has a sub out, and matches the factory dials
DRIVE-S HX
4 x 52 W S-MOSFET power output
MP3 / WMA / ATRAC playback
ID3 Tag display
Full Motion Dot Matrix FL Display
Motorised Motion Blade-plus (Synchronised Flip Front Panel)
24-bit DAC (Digital / Analog Converter)
DSO / EQ7
Parametric EQ3 (3 Band Equalizer)
2 Pre-outs + Dedicated Subwoofer Output
BBE MP Digital - High Definition Sound
WALKMAN / CD Changer Control Ready
IR card remote RM-X151 supplied
Detachable front panel
here are some pics of the sub, i got the cutting diagram from this site
http://www.subwoofertools.com/forum/ported...mp;Fs=&CE=0
its tuned to 45 hertz
  • 5 months later...
nearly a full kenwood system
kenwood head unit
ipod link
kenwood 6x9's
kenwood 1800w amp (with remote mounted on shelf)
kenwood 12" sub
alpine component door speakers n tweeters
i made the box and shelf
let me know what you think?
  • 2 months later...
  • 1 year later...
Components:
Rainbow Kick Components @ 100RMS 4ohm
RE MX tunned to 30Hz 1500RMS @ 1ohm, (possibly getting a more powerful amp ;) )
Subs been reconned atm
Probably around 120 DB's need to get tested
update of mine
12' RE MX Dual coil with 2000.RMS SPL Dynamics + 12' RE MX 1OHM
-Powerbass & Kenwood amps + 275 Rainbow kick components 400.RMS plus
-Uprating alternator to 150amnps. also adding something for mid bass @ 350.RMS
-optima yellow top
Edited by Tigz
  • 4 weeks later...
mine
pioneer headunit - deh-p3600mpb
alpine spr 176a components - 50w RMS with plenty of sound deadining in the doors ----> powered by alpine MRP-T222 two channel amp - 50w per channel at 4 ohms
had alpine type r 1221 12 inch sub (300w RMS) now pioneer tsw 3004 spl (1000w RMS according to google dont believe that for a second though lol) ----> powered by alpine MRD-M605 600w RMS single channel running at two ohms.
Edited by scoobydoo
  • 3 weeks later...
heres my install in my gti
(now has two 10"s instead of the one you see in the pics)
Clarion: VRX928RVD DVD Headunit
Pioneer: TS-E176C - 17cm Components front and rears
Powered by
Pioneer: GM-6300F Amplifier - 4 channel amp
Pioneer: TS-W257DVC - 10" 1200W subwoofer Dual Voice Coil
Powered by
Pioneer: GM-7300M Amplifier - MONO BASS AMP
Two fuse blocks and a 1.5 Farad Power Capacitor
Phoenix Gold Bass Cube
soon to have another set of components in the boot lid
heres a picture someone took from GTI inters
Edited by robgti
  • 3 weeks later...
I don't have any ICE in my Lupo as yet, but got a few bits set up in my Megane.
Its still running the standard six speakers but also runnning a pair of Pioneer 6x9s, Legacy Amp and 12" Vibe sub all running from a Pioneer head unit.
This is the headunit the Lupo will be inherting though -
And this is the new head unit I've got sitting waiting to go in the Megane -
  • 2 months later...
alright all, thought id stick mine up, got it db tested at trax by DB drag at 145.5 db @ 41hz
alpine 9866r head unit
sun down 2500 amp,
starsound 2000.4 4 channel amp
starsound ssk 165 components
oz audio matrix elite 15" sub, x2
2x yellow top batteries
clifford arrow 5.1 alarm
central and remote central locking being installed,
custom box,
HU
2x yellow tops
components (new tweaters mounted in the normal place)
subs
custom box
amps
retrimed and finished with the odd monkey and banana thrown in!
thanks alot, hope you like, rich
Edited by little rich
  • 4 weeks later...
quick look at my install.
Consists of:
mb quartz mq 218.61q components
boston acoustics G2 8" subwoofer
audison spx2 amplifier
tamagotchy 7" screen dvd headunit (has alpine guts!)
has a false floor in the boot which also has the spare wheel still in. sound deadening in the boot and in the doors and throughout the car under the carpet with all the wires running down the centre of the car.
all in all sounds really nice fancy some more bass tho listen to alot of electro, house, dnb and jungle!
Pics!..
thanks for looking :)
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
  • 3 months later...
its a sql set up andy so the fi q dual 2 is running sealed but is being given 1200 at 1 ohm from a DLS A3 its no way as lond as your blt but the sq of the system has to be heard to be appreciated i was gonna compete in emma this year but there are so many vw shows im commited to this year i just couldnt juggle the two, as for the FI one word awesome
