Vw lupo whining problems
reeceliamallsop
so my car keeps whining but its temperamental as in sometimes it will and sometimes it won't when it does the whining increases with revs. i hadn't noticed it until i had a new clutch and release bearing replaced. i hope its not going to die but this will really top off my year.
Mine does the same, almost sounds like a super charger. Has to be bearings worn out somewhere.
Thats to far away from the kitchen for it to be a woman.
Unless its a botched attempt at killing a hooker and you forgot to take it out of the boot, common problem up north.
Although lupo boots aint the most spacious
Interference can be caused by loads of things but the most common is rca's being run too close to power cables that are oem and also powers cable that power the amp. And half dead whores.
