alfa wheels 16s
causer
4 stud Alfa and Fiat wheels are 4x98 whereas VW are 4x100. They are also 56.1mm centre bore as opposed to VW 57.1mm.
Not insurmountable, wobble botls and a flappy sanding wheel on a drill, but as Scotty says though, more details needed.
Sorry yes, I stand corrected. I was looking at a set of Alfa pepperpots a while back and remebered them being 1mm outon the centre bore. It would have been easy if they were 1mm smaller as I could have enlarged them as I said. What I was wanting to do, but found it hard to come by in Perth was to increase the bore to 60mm and fit spiggots.
So if the OP can find someone to bore the centres out, or is happy to use "tape", then it is do-able.
