Removing GTI battery Bracket under bonnet ?
If you're talking the black plastic terminal box, then it's just 2 bolts either side holding it to the bracket. You might need to undo one of the cables entering the box to get to one of the bolts though.
The box on top of the bracket should just unclip from the back and the bracket itself is held on with 3 bolts. It's a doddle.
