PhilipM Posted August 15, 2012 Report Share Posted August 15, 2012 Hi, I just bought a 1.4 Lupo today and was driving it home quite the thing and the oil warning light flashed on, so I stopped the car, switched everything off, got out and checked the oil and there was plenty in it. So I continued driving, and it flashed on again, so I repeated and it was fine, so I continued driving again, but not going above 2k revs this time, and it was perfectly fine, the car doesn't make any strange sounds while driving, has anyone head of this before? Should I be worried? Quote Link to comment Share on other sites More sharing options...
tiny_landy Posted August 16, 2012 Report Share Posted August 16, 2012 Has it been serviced recently? Mine did that not that long ago and I sent it to vw to have half service and they sort it out. But I guess anywhere could service it for you Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 16, 2012 Report Share Posted August 16, 2012 Could be the oil pressure sensor thats giving false readings. VAGCOM it and replace the sensor if appropriate Quote Link to comment Share on other sites More sharing options...
grazo22 Posted August 16, 2012 Report Share Posted August 16, 2012 Were you going round a corner? Mine occasionally comes on when I'm tearing round a corner. It's a pressure light so would indicate there is a poor feed. If the oil is 100% correct I would guess oil pick up or the switch its self. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 16, 2012 Report Share Posted August 16, 2012 Were you going round a corner? Mine occasionally comes on when I'm tearing round a corner.Is the level at max? Quote Link to comment Share on other sites More sharing options...
grazo22 Posted August 16, 2012 Report Share Posted August 16, 2012 That's after its leaked for a while. Its when she's telling me she's had her supper!! Quote Link to comment Share on other sites More sharing options...
PhilipM Posted August 16, 2012 Author Report Share Posted August 16, 2012 Thanks for the advice guys and gals, I'm hoping that it was just a fluke with the electrics, but I'm getting it checked out tomorrow, so we'll wait and see. Quote Link to comment Share on other sites More sharing options...
renandstimpey Posted August 17, 2012 Report Share Posted August 17, 2012 I'm suffering a similar problem with my GTi this last week, swapped for a new sensor and it hasn't cured the problem, mine also starts to flash after the water has hit normal operating temperature, 5-10 mins of driving, and seems to be if I use over 3k revs....? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 17, 2012 Report Share Posted August 17, 2012 ^ Oh dear.Did you use a VW sensor?Any odd noises or anything? What grade oil is in it? Quote Link to comment Share on other sites More sharing options...
renandstimpey Posted August 17, 2012 Report Share Posted August 17, 2012 Yep, vw part. Oil level is just below the high mark on the stick, no noises, no running problems, no overheating, no nothing other than a blinking blinking light! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 17, 2012 Report Share Posted August 17, 2012 What does VAGCOM say?Could be a wiring fault rather than the sensor Quote Link to comment Share on other sites More sharing options...
renandstimpey Posted August 17, 2012 Report Share Posted August 17, 2012 Haven't had it plugged in, haven't got it and don't know anyone who does! I have ordered one of those leads off ebay to see what that throws up? Don't know how useful they are for the 'home' mechanic... Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 17, 2012 Report Share Posted August 17, 2012 Download the free VAGCOM off Rosstech and away you go. Its very good Quote Link to comment Share on other sites More sharing options...
PhilipM Posted August 18, 2012 Author Report Share Posted August 18, 2012 My car needs a new engine, the big end bearings are gubbed, raging doesn't describe how I feel Quote Link to comment Share on other sites More sharing options...
grazo22 Posted August 18, 2012 Report Share Posted August 18, 2012 (edited) http://www.ebay.co.u...7#ht_500wt_1203 nice little upgrade to a better engine without the problems whilst your there If you were local I'd give you a hand swapping it, a small flight away though Edited August 18, 2012 by grazo22 Quote Link to comment Share on other sites More sharing options...
renandstimpey Posted August 18, 2012 Report Share Posted August 18, 2012 My car needs a new engine, the big end bearings are gubbed, raging doesn't describe how I feelThat's really bad news! If mine is anything like that then it's getting scrapped, it's only done about 2 1/2k miles on a top end rebuild/new pistons/fresh belts and tensioners! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 18, 2012 Report Share Posted August 18, 2012 My car needs a new engine, the big end bearings are gubbed, raging doesn't describe how I feelPrivate sale I assume?Is the light on all the time or just every now and again? Any knocking noises? Quote Link to comment Share on other sites More sharing options...
PhilipM Posted August 18, 2012 Author Report Share Posted August 18, 2012 Private sale I assume?Is the light on all the time or just every now and again? Any knocking noises?When we bought the car from a used car dealer there were no funny noises and the light came on twice on the way home, so we decided to be better safe than sorry and booked it in at our local VW specialist, he went over the car with a fine toothed comb and found that the big end bearing were ruined, that the engine would last like another week before it wouldn't work at all. Quote Link to comment Share on other sites More sharing options...
Owen33 Posted August 19, 2012 Report Share Posted August 19, 2012 how is it possible to determine the big ends gone without any knocking noise?My old engine wouldn't give up when its shell went just didnt sound healthy but altough it worked was truly beyond fixable state :'(==== Is the BBY classed as a 100hp engine? sorry i just may be interested as have sport many sport spares about Quote Link to comment Share on other sites More sharing options...
grazo22 Posted August 19, 2012 Report Share Posted August 19, 2012 how is it possible to determine the big ends gone without any knocking noise?My old engine wouldn't give up when its shell went just didnt sound healthy but altough it worked was truly beyond fixable state :'(==== Is the BBY classed as a 100hp engine? sorry i just may be interested as have sport many sport spares about bby is 75bhpWhen we bought the car from a used car dealer there were no funny noises and the light came on twice on the way home, so we decided to be better safe than sorry and booked it in at our local VW specialist, he went over the car with a fine toothed comb and found that the big end bearing were ruined, that the engine would last like another week before it wouldn't work at all.You should be able to take it back then, did you have a report made by the specialist as you may need this to justify your concerns Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 19, 2012 Report Share Posted August 19, 2012 If you bought it from a dealer return it/they pay for it fixing Quote Link to comment Share on other sites More sharing options...
