biggrim Posted August 4, 2012 Report Share Posted August 4, 2012 Trying to get the sump and head off the loop so I can replace the piston rings but I can't get the sump off!I've loosened the two 16mm bolts at the gearbox housing and all the 5mm Allen head bolts around the lip of the sump. It just refuses to drop off!!! There is a little movement but it's stubborn as hell. Looks like there has been liquid gasket used in the past. Would that cause it to not want to move? I just don't want to try and persuade it off incase I've missed anything. Any help welcome and thanks in advance. Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted August 4, 2012 Report Share Posted August 4, 2012 Is there two sneaky allen head bolts right up next to the flywheel??Ive only done sump removal on a tdi which is obviously a different engine but just putting it out there incase. Quote Link to comment Share on other sites More sharing options...
biggrim Posted August 4, 2012 Author Report Share Posted August 4, 2012 I think I got them Scotty but I'll double check when the torrential rain stops. It could just be the liquid gasket has a good hold of it but I'd rather be 100% about sufficient bolt removal before I try to persuade it off. Quote Link to comment Share on other sites More sharing options...
biggrim Posted August 4, 2012 Author Report Share Posted August 4, 2012 Oh, THOSE two hidden little Allen head bolts. They are not impossible to get to at all. Long ball-ended 5mm Allen key to the rescue hopefully. Are these prone to rounding easily? If they are, what are my options if they do? Cheers matey. Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted August 4, 2012 Report Share Posted August 4, 2012 Of you crank the engine over with a socket the flywheel should have a notch that allows a long t handle Allen driver to get on to them Quote Link to comment Share on other sites More sharing options...
Rich Posted August 4, 2012 Report Share Posted August 4, 2012 Of you crank the engine over with a socket the flywheel should have a notch that allows a long t handle Allen driver to get on to them, I'm also gay.Not on a GTI Scotty, only the TDI.Use a ball ended allen key on a ratchet if possible and you should be fine.Now, do I point out the obvious or do I just stay quiet? Quote Link to comment Share on other sites More sharing options...
biggrim Posted August 4, 2012 Author Report Share Posted August 4, 2012 Point away matey. Quote Link to comment Share on other sites More sharing options...
biggrim Posted August 4, 2012 Author Report Share Posted August 4, 2012 Wait. Just noticed the modified quote lol. 1 Quote Link to comment Share on other sites More sharing options...
Rich Posted August 4, 2012 Report Share Posted August 4, 2012 That's not the point, these aren't overly fond of replacing the piston rings, just find a new engine and run it only on V power. Quote Link to comment Share on other sites More sharing options...
biggrim Posted August 5, 2012 Author Report Share Posted August 5, 2012 Don't have the cash for a new engine so rings will have to do for now I'm afraid. Got the sump off guys. Thanks for your help Quote Link to comment Share on other sites More sharing options...
Owen33 Posted August 5, 2012 Report Share Posted August 5, 2012 Where did you get the bits for the job? And are you only doing rings? Quote Link to comment Share on other sites More sharing options...
biggrim Posted August 5, 2012 Author Report Share Posted August 5, 2012 Haven't actually got the bits yet but will most likely get it all through Halfords (via DINGBRO) who I've got bits off in the past. Going to replace the water pump, timing belt/tensioner and spark plugs too. Anything lest I should consider since it's in bits? Quote Link to comment Share on other sites More sharing options...
Owen33 Posted August 5, 2012 Report Share Posted August 5, 2012 I'm doing mine to a very small budget, doing rings, big end bearing shells for the internal, then the rest is just gaskets, bolts and service parts, belts and gaskets etc.This is first time i've done this so probably not the best for infoTry Lupoboz on here in the 'genuine traders' Section he does great prices. Would imagine save a fortune over halfords! Quote Link to comment Share on other sites More sharing options...
biggrim Posted August 5, 2012 Author Report Share Posted August 5, 2012 First time here too matey. Steep learning curve but should be worth it in the end. Plus I can't afford to pay someone to do it at the moment. Gives me an excuse to get out on my bike and loose a few lbs. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 7, 2012 Report Share Posted August 7, 2012 I didnt think the piston rings were an issue on the GTI? Quote Link to comment Share on other sites More sharing options...
GeoffD Posted August 10, 2012 Report Share Posted August 10, 2012 i normally use euro car parts, youll find them on the interweb and theyre cheap. the prices are usually a guide theyre normally cheaper when you phone them. i would probably give the bores a light hone too just dont get carried away, good luck and plenty clean engine oil when you put it back together. geoff Quote Link to comment Share on other sites More sharing options...
biggrim Posted August 11, 2012 Author Report Share Posted August 11, 2012 Can I ask a silly question? Is the stretch bolt at the aux pulley on the block a normal or a reverse thread? I can NOT get the bugger to move. It's the only thing holding me back at the mo and it's really infuriating! Any pointers?Cheers,Graeme Quote Link to comment Share on other sites More sharing options...
Owen33 Posted August 11, 2012 Report Share Posted August 11, 2012 (edited) Sport engines are normal direction, just hella tight. get MORE leverage Also does anyone know if the rings have a run-in procedure?PS @ Sophie if you bought your lupo from consett... FU we wanted it! Edited August 11, 2012 by Owen33 1 Quote Link to comment Share on other sites More sharing options...
biggrim Posted August 12, 2012 Author Report Share Posted August 12, 2012 Cheers Owen. Just wanted to clear that up before I began to tighten it even more. More leverage??? It can't be that tight can it? I've got a mate in the car with it in gear, foot on the brake and me underneath with a 16 or 18 inch breaker bar. I'm going to end up giving myself a hernia lol. I'll see if I can get a hold of a longer bar. Cheers matey. Quote Link to comment Share on other sites More sharing options...
GeoffD Posted August 12, 2012 Report Share Posted August 12, 2012 no, if it makes you feel better owen we had to go to bloody wigan to get ours but it was worth it Quote Link to comment Share on other sites More sharing options...
biggrim Posted September 5, 2012 Author Report Share Posted September 5, 2012 Quick update folks. After a stubborn crank bolt delayed me by 2 weeks (I know, I know) the head is now off and the pistons out. Going to replace the water pump whilst it's all in bits but not too sure how to get it off. Anyways. Ordering all the bits I need this week so if all goes well, should have her back in the road in a couple of weeks Quote Link to comment Share on other sites More sharing options...
Owen33 Posted September 5, 2012 Report Share Posted September 5, 2012 i've done nearly 1500 miles on my rebuild all is fine. altough i had to get some k seal from euro car parts. An additive to the coolant system as it was steaming from exhaust... HeadGasket ? put it through ran it to opperating temperature and it was cured i'm told i should have had the head skimmed? might be something for you to consider ! Quote Link to comment Share on other sites More sharing options...
Fez190 Posted April 1, 2013 Report Share Posted April 1, 2013 Sorry ive got the same problem with getting the sump off, are we saying there are two 5mm allens flywheel end up in those little holes? Quote Link to comment Share on other sites More sharing options...
Rich Posted April 1, 2013 Report Share Posted April 1, 2013 yes. Quote Link to comment Share on other sites More sharing options...
