Kieranbolton Posted February 26, 2012 Report Share Posted February 26, 2012 Hello everyone, can anyone give me a hand? installing this Rclick kit it seems to be a pain in the backside really, to be honest, i wish i never started, but never mind Few last problems now, if anyone can help me it would be great 1, the passenger side door, has a bar on it, pictured below with 2 blue marks on, (gray) where can i buy these? or do they only come complete with the lock etc etcSecond off if i wire the 2 brown indicator flashers into the hazard warning switch will it be okay? if so how can i remove the harzard warning switch?Thanks in advanceKieran Quote Link to comment Share on other sites More sharing options...
Kieranbolton Posted February 26, 2012 Author Report Share Posted February 26, 2012 without creating another thread, which wires do i need to piggy back for the indicator to work? Quote Link to comment Share on other sites More sharing options...
Rosie02 Posted February 26, 2012 Report Share Posted February 26, 2012 hay, you wiring in like central lock/ alarm for like indicator flash? if so put your hazard switch back and the wires are under the steering wheel you want.Green/BlackWhite/BlackThe ones i am probing in the picture above. I would do the same just to make shore this is right before cutting them.If you cut them and solder them all back together with the locking as well then that should be a proper job with some heat shrink.Hope to help. Quote Link to comment Share on other sites More sharing options...
Kieranbolton Posted February 26, 2012 Author Report Share Posted February 26, 2012 Hey rosie cheers for that, its a pointer in the right direction i hope My layout is diffrent to yours slightley but ill give it a bash, if the wires are the same Ive also got solder and heatshrink so i can do a proper job i used to play around with electronics about a year back,Ill get the multimeter on those 2 wires and ill see what happens Thanks a bunch Kieran Quote Link to comment Share on other sites More sharing options...
Rosie02 Posted February 27, 2012 Report Share Posted February 27, 2012 No worrys, I took pic when I installed my toad alarm so still fresh on the info. And didn't realise they were layed out differently. Quote Link to comment Share on other sites More sharing options...
Kieranbolton Posted February 27, 2012 Author Report Share Posted February 27, 2012 no problems rosie, nipped out just now tested it, works lovely The wires are the same color etc, but where you have the connector blocks, i don't have them, for example the massive one there for the air bag, i don't have that, but the red one that is still connected on the ignition barrel, Ive got that but dont have the one where you have stuck the wires in Thankyou for all your help anyway, massive hand Kieran Quote Link to comment Share on other sites More sharing options...
mrw2311 Posted October 4, 2012 Report Share Posted October 4, 2012 Hiya guys, sorry to dig up an old thread, but where did you get your 12v live feed from? Is there a live feed under the steering wheel where the indicator wires are?Cheers Quote Link to comment Share on other sites More sharing options...
