igotbeef Posted February 20, 2012 Report Share Posted February 20, 2012 was wondering if anyone has had the same problem as i have with the clutch peddle? basically it goes down about 2 inches very easily before it feels resistance, the pedal moves side to side about 1cm if you wiggle it with your hand? does this mean the peddle box is on it's way out? any help would be appreciated thanks. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted February 21, 2012 Report Share Posted February 21, 2012 Sounds like it. Quote Link to comment Share on other sites More sharing options...
igotbeef Posted February 25, 2012 Author Report Share Posted February 25, 2012 i know the fault is with the weld on the back but the box still seems stuck ok just the clutch arm/peddle woggling a bit. Quote Link to comment Share on other sites More sharing options...
