grazo22 Posted January 27, 2012 Report Share Posted January 27, 2012 Ma pal has a lupo 1.4sIt was working fine, the under dash has been taken off to route a usb cable from the stereo. It was coming out the front before and working fine.Mid way though this process there was a flash from the interior light when he was removing the battery, ignition off.We've put the car back together and there is no power, to anything, voltage accross the battery is normal, fueses in the box are all working, apart from the cigarette lighter and radio but these have been gone for ages. The fuses on the battery are all okay as well so I'm completely lost.When you turn the key there is no noise of the fuel pump, the car wont lock or unlock and no interior lights, absolutely nothing.I've run out of my lupo knowledge so am after a little help, any suggestions would be great.TIA Quote Link to comment Share on other sites More sharing options...
nick123 Posted January 27, 2012 Report Share Posted January 27, 2012 (edited) possible short to ground on battery negative, check clearance Edited January 27, 2012 by nick123 Quote Link to comment Share on other sites More sharing options...
nick123 Posted January 30, 2012 Report Share Posted January 30, 2012 any updates? Quote Link to comment Share on other sites More sharing options...
grazo22 Posted January 30, 2012 Author Report Share Posted January 30, 2012 Turned out he had disconnected the sub from one of the bolts on the fuse box on the battery. It was dark at the time so took ages to find.Sorted and all working now Quote Link to comment Share on other sites More sharing options...
