chimpie Posted January 27, 2012 Report Share Posted January 27, 2012 Hi all,I wonder if anyone can give me any tips to help me out here, i have checked the other 'washer' related posts, but non seem to address this as far as i can see. the other day on my seat arosa, all my washers stopped working, it turns out i was kinda stupid and filled the reservoir without checking to see if there were any old leaves in the watering can. anyway to cut a long story short, i got them all unblocked. The problem i am having is this. on the rear washer i removed the motor etc and got it cleared, but i also removed the pipe from the connector which attaches to the jet on the wiper motor (following me?) i can't for the life of me get it back on, does anyone have any tips, i have tried boiling water to soften it (not the kind of plastic to soften in hot water) tried a lighter to heat it and soften it (just ruined the pipe so had to shorten it).Any help would be greatly appreciated as it is driving me nuts. chimpie Quote Link to comment Share on other sites More sharing options...
chimpie Posted February 2, 2012 Author Report Share Posted February 2, 2012 nobody? 51 views, and no one has ever encountered this? Quote Link to comment Share on other sites More sharing options...
treblet Posted February 2, 2012 Report Share Posted February 2, 2012 It should go back on but you could always try using some rubber vacuum tubing or fuel line tubing over the old tubing and then shove that on the motor if you can't get it to fit.Just make sure you cable tie the tube inside so it doesn't pop off! Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted February 10, 2012 Report Share Posted February 10, 2012 as above Quote Link to comment Share on other sites More sharing options...
