angelo77 Posted January 27, 2012 Report Share Posted January 27, 2012 (edited) Not sure if this is the right place to post this,I purchased a used lower strut brace which arrived today (thanks james)I am going to make a new one to the same design out of heavier gauge material as its a bit flimsy,The finsh will either be galvanised or zinc coat as it will be exposed to the elementsI might powder coat for finishIts probably going to cost me with materials, time and then finsh approx £50 - £70If anyone wants one or if there is enough interest ill make a few more at the same time.This is not for profitMods if Im breaking any rules please deletePictures:Kind RegardsAngelo Edited January 27, 2012 by angelo77 Quote Link to comment Share on other sites More sharing options...
AJ Joyce Posted January 27, 2012 Report Share Posted January 27, 2012 Fancy postin a pic of the one uv just got? Might be intrested Quote Link to comment Share on other sites More sharing options...
angelo77 Posted January 27, 2012 Author Report Share Posted January 27, 2012 Will do, probably be tomorrow, Quote Link to comment Share on other sites More sharing options...
Cooper_GTI Posted January 27, 2012 Report Share Posted January 27, 2012 I might go for one, depending on how low it sits when fitted.Also, weight is a factor for me. Quote Link to comment Share on other sites More sharing options...
angelo77 Posted January 27, 2012 Author Report Share Posted January 27, 2012 Weight wise, there is nothing in it, going to have a look at using a 25mm x 40mm box section for the main part with the circular hollow section retained for the connection, this will reduce the protrusion under the car by 15mm.I might even have some stainless steel in this size, going to have a play over the weekend. Quote Link to comment Share on other sites More sharing options...
