No compression
Hi
Been havin problems with the car juddering so after changing allsorts decided to do the timing belt, water pump and tensioners.
Went to start the car up after and it is turning over but nothing else happening.
I have fuel and spark but 0 compression on all 4 cylinders.
The cylinders turn so not thinking woodruff key??
Not sure what to check or do next any help would be appreciated
Cheers
Sands
Ah I see ill go redo the timing belt :-(, I found some white gloop in the oil, would that be part of the timing too or something more sinister?
Cheers
That to me suggests something more sinister.. any loss of coolant?
Phew nice one :-)
Yeah I put a compression check and got 0 on all of them, it didn't even move.
I lined the chamfered cog up on the crankshaft with the right hand side notch on the engine case,
And I put 8mm drill bits into each of the holes on the cam shafts, it was a bit fiddly but they seemed to line up just nice? And I set the tensioners as the diagram
How do you post pics and I'll put one up to see if I have done it right?
Cheers again
