maxwell Posted December 10, 2011 Report Share Posted December 10, 2011 im looking at getting my bumpers smoothed, does anyone know where and how much i can get this done for?or does anybody have smooth bumpers they want to swap for standard sport bumpers? (black)cheers Quote Link to comment Share on other sites More sharing options...
DarkStryder360 Posted December 10, 2011 Report Share Posted December 10, 2011 Local body shop no doubt a good starter. 200 odd for front n back probably. Quote Link to comment Share on other sites More sharing options...
Kent Posted December 10, 2011 Report Share Posted December 10, 2011 I'd say more than £200 ... £200 would cover front only or back only possibly. Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted December 10, 2011 Report Share Posted December 10, 2011 Yeah id say just to spray them would be 100 notes per bumper easy, then the work on top of that so it could easy be the 400 mark. Quote Link to comment Share on other sites More sharing options...
HalfOfZero Posted December 10, 2011 Report Share Posted December 10, 2011 Go to a local scrappies and dig out a few bumpers, do some research and buy some equipment you'll need, and try it yourself.Even if you just get the bodywork part out of the way then get it sprayed, it'll still be alot cheaper, and more fun lol. Just my two copper pennies worth though.. Quote Link to comment Share on other sites More sharing options...
lupygav Posted December 11, 2011 Report Share Posted December 11, 2011 Stylhaus reckon around a couple of hundred quid just for the front.G Quote Link to comment Share on other sites More sharing options...
maxwell Posted December 11, 2011 Author Report Share Posted December 11, 2011 probably going to DIY it! will let you know how it goes. cheers Quote Link to comment Share on other sites More sharing options...
HalfOfZero Posted December 11, 2011 Report Share Posted December 11, 2011 Search on here cause I found a good few threads on it, some people get detailed with it. Youtube too Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted December 11, 2011 Report Share Posted December 11, 2011 i done a front bumper butiits ****e, if i wer to do it again id definately use two bumpers, to ensure the profile of the bumper remains the same the plastic welding is the easy part its getting the profile to match thats the difficult partbuy a solder iron with a relatively broad tip and ur good to go Quote Link to comment Share on other sites More sharing options...
pev Posted December 12, 2011 Report Share Posted December 12, 2011 i done a front bumper butiits ****e, if i wer to do it again id definately use two bumpers, to ensure the profile of the bumper remains the same the plastic welding is the easy part its getting the profile to match thats the difficult partbuy a solder iron with a relatively broad tip and ur good to goThat's the same problem I had, I used fibre glass filler stuff around the plastic welding and it's almost impossible to get it all even with it being so solid Quote Link to comment Share on other sites More sharing options...
Widelupo Posted December 15, 2011 Report Share Posted December 15, 2011 How do you smooth the bumper do you just use filler. Or plastic weld. Quote Link to comment Share on other sites More sharing options...
Guest trio Posted December 17, 2011 Report Share Posted December 17, 2011 How do you smooth the bumper do you just use filler. Or plastic weld.slapping filler on ftlplastic weld all the way Quote Link to comment Share on other sites More sharing options...
