corey2456 Posted November 16, 2011 Report Share Posted November 16, 2011 hello everyone, I'm a bit new to this,i have a seat arosa 1.0 s and it hesitates of idle. its not a major problem its just one of these things that does your head inwhen you start the engine and let it settle to idle (550-650rpm that sounds low to me but someone told me its about right for a 1.0l engine) and if you put you foot down quickly (anything from full to a quarter) the revs drop down, it makes a sucking air sound from the carb (or fly by wire equivalent) and hesitates picking up, when pulling out of a junction you have to build the revs up past 1000rpm to be able to pull of properly. the revs drop so much that if you turn the steering wheel (strain on the engine) and press the throttle at the same time it will stall 50% of the time (in neutral)any ideas or suggestions will be greatly appreciated, any questions don't be afraid to ask thanks Quote Link to comment Share on other sites More sharing options...
