Pete Posted November 1, 2011 Report Share Posted November 1, 2011 Sorry everyone, I know this subject has been covered quite a bit, but I looked through a load of old topics and couldn't make head nor arse of the pics posted up, all I need is a decent, pretty clear shot of where the breather pipes should be routed with a BMC CDA fitted, as obviously they aren't used with the normal pipe work which goes with the CDA, I get the impression a catch tank is needed but there are two breather pipes, which one should it be connected to? Both?? Is there a certain position it should be in?! Help! Quote Link to comment Share on other sites More sharing options...
Pete Posted November 1, 2011 Author Report Share Posted November 1, 2011 Nobody?? Quote Link to comment Share on other sites More sharing options...
JoeA Posted November 2, 2011 Report Share Posted November 2, 2011 (edited) If they both go into the air box, id run them both into the bmc pipework, my mate with a BMC bought a valve that screws into a hole he drilled in the silicon pipe and his breather runs into that. Edited November 5, 2011 by joeadamou Quote Link to comment Share on other sites More sharing options...
Pete Posted November 2, 2011 Author Report Share Posted November 2, 2011 Cheers joe, I assume I'd have to plumb them both into opposite sides of the pipe. Fanx! Quote Link to comment Share on other sites More sharing options...
JoeA Posted November 5, 2011 Report Share Posted November 5, 2011 s'okay, post some pics when you've done it Quote Link to comment Share on other sites More sharing options...
joshuaar Posted November 5, 2011 Report Share Posted November 5, 2011 Pretty sure I have a couple of valves from my oil catch tank lying around if you want them mate? Quote Link to comment Share on other sites More sharing options...
Kam Racing Posted November 10, 2011 Report Share Posted November 10, 2011 the reason people go for catch tanks or breather filters is because the oil does not burn in the engine when routed back in via induction and is therefore meant to loose you a bit of power Quote Link to comment Share on other sites More sharing options...
