marcusgrant Posted August 17, 2011 Report Share Posted August 17, 2011 As title really, looking into getting a mk4 anni, petrol or diesel.Just wondering if anyone on here has had one or knows much about them? They good? Any common problems?Cheers Quote Link to comment Share on other sites More sharing options...
99hjhm Posted August 17, 2011 Report Share Posted August 17, 2011 PD150's eat camshafts. Budget £1000 for repairs at a garage. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 17, 2011 Report Share Posted August 17, 2011 Has it been established what caused the chocolate cam problems? Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted August 17, 2011 Author Report Share Posted August 17, 2011 ah, i would prefer the petrol one There was one forsale 10 miles from me on autotrader, 56k, fsh, black ....4.5k! when i saw it and rang up it had already sold They seem to demand quite strong money Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted August 17, 2011 Author Report Share Posted August 17, 2011 A friend his selling his diesel one. I can get you full spec if you like?Can do mate Not really interested in it though if its been modified. Im after a really well look after, totally standard one with fsh. hopefully i'll one will pop up on the private adds one day! Quote Link to comment Share on other sites More sharing options...
Mike_M Posted August 18, 2011 Report Share Posted August 18, 2011 Go on UKMKIVS.netAs said the PD150 eat cams.I used to work at VW HQ and we had a lot of warranty claims on the the BBS rims as they were originally polished on the 25th anni and corroded then BBS took them back under warranty and replaced them for free until it came to a point that it was becoming silly and they exchanged them for the normal silver version you could buy.If it is silver, also check there is no clouding in the side skirts as this was another issue. They looked almost grey out the factory.........must have been a curing process issue.The 1.8T 25th anni is my preference with 180bhp and it sounds good too Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted August 18, 2011 Author Report Share Posted August 18, 2011 Cheers for the info mike Quote Link to comment Share on other sites More sharing options...
Bikerz Posted August 18, 2011 Report Share Posted August 18, 2011 The 130 GT TDI is the one to get. Comes with a 6 speed box and only difference is the turbo (The 150 is ceramic coated internals apparently) size is the same. Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted August 18, 2011 Author Report Share Posted August 18, 2011 As Ben says, its got to be an anniversary Quote Link to comment Share on other sites More sharing options...
Mike_M Posted August 18, 2011 Report Share Posted August 18, 2011 Here is my old Mk4 Quote Link to comment Share on other sites More sharing options...
treblet Posted August 18, 2011 Report Share Posted August 18, 2011 The 130 GT TDI is the one to get. Comes with a 6 speed box and only difference is the turbo (The 150 is ceramic coated internals apparently) size is the same.That isn't the only difference...The PD150 engine cams are reground 130 cams hence the chocolate cam problem and the 150 has a front mounted intercooler rather than side mounted. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted August 18, 2011 Report Share Posted August 18, 2011 Cams are the same, nobody knows what kills them.Turbo, intercooler are different, and the map of course.PD150 has 12.9 grade head bolts over 10.9 on the PD130.Oh yeah... 20BHP! lol Quote Link to comment Share on other sites More sharing options...
nfbr Posted August 18, 2011 Report Share Posted August 18, 2011 (edited) Has it been established what caused the chocolate cam problems?Abuse of the Long-life Servicing schedules which the vast majority of PD150's were sold with...After 12,000 miles the oil separates into thick and thin... like a lava lamp almost. The heavy thick stuff stays at the bottom which means only the lighter thinner oil reaches the top end due to the oil strainer getting nearly blocked.Cams are the same, nobody knows what kills them.PD100, 115, 130's all use the same amount of lift on the cams. PD150 cams are a higher lift.The 150 is ceramic coated internals apparentlyLOL! Edited August 18, 2011 by nfbr Quote Link to comment Share on other sites More sharing options...
99hjhm Posted August 18, 2011 Report Share Posted August 18, 2011 PD100, 115, 130's all use the same amount of lift on the cams. PD150 cams are a higher lift.Same part number for 130 and 150 on ETKA?Marcus... There is a guy on Edition with a Anni' that only has 6 miles on it from new!!!! Never used on the road! Quote Link to comment Share on other sites More sharing options...
Bikerz Posted August 19, 2011 Report Share Posted August 19, 2011 That isn't the only difference...The PD150 engine cams are reground 130 cams hence the chocolate cam problem and the 150 has a front mounted intercooler rather than side mounted.Sorry I did know that. Just being stupid for a moment (happens all the time) Quote Link to comment Share on other sites More sharing options...
Bikerz Posted August 19, 2011 Report Share Posted August 19, 2011 Abuse of the Long-life Servicing schedules which the vast majority of PD150's were sold with...After 12,000 miles the oil separates into thick and thin... like a lava lamp almost. The heavy thick stuff stays at the bottom which means only the lighter thinner oil reaches the top end due to the oil strainer getting nearly blocked.PD100, 115, 130's all use the same amount of lift on the cams. PD150 cams are a higher lift.LOL!Wasnt just me that thourght that was a werid statement then. What is the difference Al? Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted August 19, 2011 Author Report Share Posted August 19, 2011 Same part number for 130 and 150 on ETKA?Marcus... There is a guy on Edition with a Anni' that only has 6 miles on it from new!!!! Never used on the road!Really?! is it for sale?? Any links to it? Quote Link to comment Share on other sites More sharing options...
Bikerz Posted August 19, 2011 Report Share Posted August 19, 2011 Really?! is it for sale?? Any links to it?Take a wild guess.......NO Id imagine! Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted August 19, 2011 Author Report Share Posted August 19, 2011 Take a wild guess.......NO Id imagine!LOL what a bell end. Quote Link to comment Share on other sites More sharing options...
nfbr Posted August 20, 2011 Report Share Posted August 20, 2011 Same part number for 130 and 150 on ETKA?Shouldn't be? Unless they've reverted to putting PD130 cams in 150's now?Wasnt just me that thourght that was a werid statement then. What is the difference Al?From what I can make out, the PD130 and 150 bottom end is identical. Quote Link to comment Share on other sites More sharing options...
Greig Posted August 20, 2011 Report Share Posted August 20, 2011 Had one and loved it. Best car I've owned and regret selling it, but student needs a must. Mine was a 1.8t and completely standard with 62k. Then the guy I sold it to modded it with silly wheels.IMO they should be kept standard, with someEngine mods and lowered at the most. Would have another in a heart beat Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted August 20, 2011 Author Report Share Posted August 20, 2011 Well looks like i wont be getting one now put a deposit down on a 58 plate A3 1.4T FSI today Quote Link to comment Share on other sites More sharing options...
