smitty12 Posted April 27, 2011 Report Share Posted April 27, 2011 My 1.4 16v 75bh Lupo is about to die so i'm in need of a new engine.I want to stick the 100bh sport engine in replacement, does anyone know the engine codes for the sport engine?And can anyone give me any advice on the conversion/issues that need overcoming.My lupo is on a w reg so not sure if the wiring looms are different or if its just a case of plug and play with swapped ECUIf anyone knows of a sport engine in the Newcaslte/Gateshead area could you let me know aswel Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted April 27, 2011 Report Share Posted April 27, 2011 There are two -AFK - very early sportsAUB - later sports, think about mid 2000 onwards.They are slightly different engines and if you have an AUB sport a AFK won't fit (easily anyway). I know AFK doesn't have an EGR valve and there are 4 instead of 6 screws that go from the sump to the gearbox, not sure about anything else. As on has egr and one doesnt the ECU's will have a different amount of pins to.Chrisc on here had a 75bhp lupo with a sport lump so might be worth having a word with him. Quote Link to comment Share on other sites More sharing options...
smitty12 Posted April 27, 2011 Author Report Share Posted April 27, 2011 cheers mate,I need this conversion starting ASAP or i'm going to be stuck with sticking another 75bh which i really dont want to do!!! Quote Link to comment Share on other sites More sharing options...
ChristopherReeve Posted April 27, 2011 Report Share Posted April 27, 2011 If you're going through the hassle Of a engine conversion I'd get a polo gti engine, couldn't you go down that route instead? Quote Link to comment Share on other sites More sharing options...
smitty12 Posted April 27, 2011 Author Report Share Posted April 27, 2011 If you're going through the hassle Of a engine conversion I'd get a polo gti engine, couldn't you go down that route instead?I had thought about that but the conversion would be far more complicated and the engine is initially a higher cost. My 75bh engine is about to die so i want a quick ish conversion, the sport engine seems ideal to me as thats what i origionally wanted. + i've just had my box referbed and had a new clutch, alternator and battery that will all go onto the sport engine. Quote Link to comment Share on other sites More sharing options...
ChristopherReeve Posted April 27, 2011 Report Share Posted April 27, 2011 I had thought about that but the conversion would be far more complicated and the engine is initially a higher cost. My 75bh engine is about to die so i want a quick ish conversion, the sport engine seems ideal to me as thats what i origionally wanted. + i've just had my box referbed and had a new clutch, alternator and battery that will all go onto the sport engine.Oh right fair enough it makes sense. It's hard to get a sport engine but someone is selling a engine and ecu on club lupo, think he's called rich? You should pm him. Quote Link to comment Share on other sites More sharing options...
