Bickerton Posted March 19, 2011 Report Share Posted March 19, 2011 (edited) Car died the other day and wouldn't start, AA man gave up after trying lotsa things, today i removed the belt cover (10second job..) to findWhat are my options please? Edited March 27, 2011 by Bickerton Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted March 19, 2011 Report Share Posted March 19, 2011 Its probably bent valves and scored the piston tops, possibly could have fubared the head too. Quote Link to comment Share on other sites More sharing options...
Bickerton Posted March 19, 2011 Author Report Share Posted March 19, 2011 Okies, in the process of stripping it all down atm Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted March 19, 2011 Report Share Posted March 19, 2011 Bit gutted , its never going to be a cheap fix , you can only hope the damage is not to bad. Quote Link to comment Share on other sites More sharing options...
Bickerton Posted March 19, 2011 Author Report Share Posted March 19, 2011 Yeah , i have everythig crossed atm lol Quote Link to comment Share on other sites More sharing options...
chris c Posted March 19, 2011 Report Share Posted March 19, 2011 at least its only the linkage belt which means one set of valves might be ok fingers crossed dude Quote Link to comment Share on other sites More sharing options...
Dz1981 Posted March 19, 2011 Report Share Posted March 19, 2011 Any news mate ? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted March 19, 2011 Report Share Posted March 19, 2011 Car died the other day and wouldn't start, AA man gave up after trying lotsa things, today i removed the belt cover (10second job..) to findWhat are my options please?AA man is a fool. First thing he should have checked.Probably valves, head set, and a cambelt kit if your luckly. Change all the stem seals too. Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted March 19, 2011 Report Share Posted March 19, 2011 about 1k worth of work at a garage Quote Link to comment Share on other sites More sharing options...
Bickerton Posted March 20, 2011 Author Report Share Posted March 20, 2011 The amount of specific tools i need is getting rather annoying atm Bottom pulley is aa ball ache,gonna see if can get hold of a tool tomorrow off a mate.Part of me keeps thinijng maybe worth trying a gti conversion but cba to do it myself, anywhere specifically does this on a supply/fit basis and rough ideas on price? Quote Link to comment Share on other sites More sharing options...
mat.m. Posted March 20, 2011 Report Share Posted March 20, 2011 ask 'nayr' his snapped a few months ago Quote Link to comment Share on other sites More sharing options...
little rich Posted March 20, 2011 Report Share Posted March 20, 2011 Dont gti it, or if you do go to a place thats done it before and 100% know what there doing,as marcus said your looking at about the 1k mark to take your car into a garage and come back working.. Quote Link to comment Share on other sites More sharing options...
Bickerton Posted March 20, 2011 Author Report Share Posted March 20, 2011 Yours still not running right? Quote Link to comment Share on other sites More sharing options...
Bickerton Posted March 21, 2011 Author Report Share Posted March 21, 2011 Had a potter about today, decided to give up, and gonna sell off my wheels and coilovers and buy a ****ter and sell the car on as a non runner i thinks Quote Link to comment Share on other sites More sharing options...
Cooper_GTI Posted March 21, 2011 Report Share Posted March 21, 2011 I'd at least whip the head off and have a quick peek!You never know, there might not have been any contact.Nothing to lose at the end of the day! Quote Link to comment Share on other sites More sharing options...
Bickerton Posted March 21, 2011 Author Report Share Posted March 21, 2011 I fitted a new belt to test for that with a compression tester, failed miserably, also the water i drained from the system 2 days ago is still not dry on my drive so that's gotta have alot of oil in it Quote Link to comment Share on other sites More sharing options...
dublove89 Posted March 21, 2011 Report Share Posted March 21, 2011 my linkage belt went on my lupo 1.4 16v 75bhp engine mid last year, i just turned the key to start it up and then i heard the dreaded noise. upon inspection ALL 16v's were bent, but i had no piston damage on any cylinder. i ended up going all out and having the head rebuilt, valve seats re-cut, new guides, stem seals, 16 new valves, etc and it was a pricey job it cost me around 600 quid for all the parts and the labour for the head rebuild, but i built it back up myself once i got the head back so saved abit of money there. my mates also did the same trick after mine went but funds were tight for him so we went about doing it on a budget, we sourced a head from a mk4 golf 1.4 16v AHW lump from a scrap yard, we gave his head and 50 quid in an exchange, bought the timming belt kit from gates for £90, a head gasket and head bolts from GSF for about 25 quid and a new water pump whilst we were at it. put it all back together and it ran sweet, the only problem was that the head from the golf didnt use an egr valve, which wasnt a problem because a blanking plate was made and that did the trick, ive heard that lupos run in limp mode when the egr valve is removed, but this one ran sweet as a nut didnt run in limp mode or anything or the sort. so you can fix it for cheap enough if you source a cheap head, it cost little over 200 quid doing it this way, i also got a brilliant diagram and instructions off the gates website for timing the engine up which helped me alot. i read earlier you were having trouble with the bottom pulley?, i used a snap on 18v impact gun to remove mine.hope this helps,Mark Quote Link to comment Share on other sites More sharing options...
Bickerton Posted March 21, 2011 Author Report Share Posted March 21, 2011 Thanks for the info matey, managed to do the pully by putting the car in gear and putting foot on brakes thus locking the engine Quote Link to comment Share on other sites More sharing options...
Cooper_GTI Posted March 22, 2011 Report Share Posted March 22, 2011 If all you've got is besnt valves, take the head off and recon it yourself. There's nothing to building a head. If you've never done it before, it'll be a good learning curve for you. Quote Link to comment Share on other sites More sharing options...
Bickerton Posted March 22, 2011 Author Report Share Posted March 22, 2011 What toolsI need to remove head bolts Quote Link to comment Share on other sites More sharing options...
Cooper_GTI Posted March 22, 2011 Report Share Posted March 22, 2011 Not sure on the Lupo, but on a lot of cars they use inverted torx bits.On my old vauxhall redtop an 11mm socket fitted perfect, as i had sheared my head bolt torx bit.Just unbolt the inlet/exhaust manifolds, unplug any sensors/wires going to the head, whip the cambelt off then undo the head bolts. There is a set sequence to undo/tighten the head bolts, but the info should be on here somewhere. I've never bothered when undoing them, just slacken them off a bit at a time. Quote Link to comment Share on other sites More sharing options...
Bickerton Posted March 22, 2011 Author Report Share Posted March 22, 2011 Seems the head bolts are yet more spliune bolts lol. This really isn't going well..Anyone know of a mechanic round coventry that would rebuild this a little cheaper than a garage? Quote Link to comment Share on other sites More sharing options...
ThE gOg Posted March 22, 2011 Report Share Posted March 22, 2011 sorry to hear about your troubles mate.out of interest how many miles had it done since the last belt change? Quote Link to comment Share on other sites More sharing options...
treblet Posted March 22, 2011 Report Share Posted March 22, 2011 You can probably get hold of a second hand engine with ecu and box for around £400 maximum.Drop that in and you're back up and running. Quote Link to comment Share on other sites More sharing options...
