Widelupo Posted March 10, 2011 Report Share Posted March 10, 2011 my engine started shuddering the other day. so took it to the garage and found out one off the spark plugs have been flooded with oil. the mechanic said i need a new engine. what do guys think??? Quote Link to comment Share on other sites More sharing options...
Bickerton Posted March 10, 2011 Report Share Posted March 10, 2011 i think the rocker cover may just be leaking. Did he do a compression test? Quote Link to comment Share on other sites More sharing options...
Silver! Posted March 10, 2011 Report Share Posted March 10, 2011 You'll need a compression test done. Valve stem seals are fairly common I think. Possible piston rings. Quote Link to comment Share on other sites More sharing options...
Widelupo Posted March 10, 2011 Author Report Share Posted March 10, 2011 i will get a compression test done on sat. so this isnt too serious?? Quote Link to comment Share on other sites More sharing options...
rh203 Posted March 10, 2011 Report Share Posted March 10, 2011 I had this but it was just the plastic extender for the oil cover (makes it high enough to reach above the plastic engine cover). I just took it off and put the cap straight on the engine and havn't had a problem since! Bobbo on here has the car now so he could probably explain better. Quote Link to comment Share on other sites More sharing options...
matt~black Posted March 10, 2011 Report Share Posted March 10, 2011 my engine started shuddering the other day. so took it to the garage and found out one off the spark plugs have been flooded with oil. the mechanic said i need a new engine. what do guys think???hang on a minute are you just talking about the hole that the spark plug goes into? oil in there is from the rocker cover gasket (silicone sealant in this case) if your doing it yourself it's a case of removing and re-fitting cambelt to get to it. If your not you may aswell have a new cambelt while your at it if it's anywhere near due as you're paying the labour anyway Quote Link to comment Share on other sites More sharing options...
Bickerton Posted March 10, 2011 Report Share Posted March 10, 2011 Was the engine cold when it started shuddering perchance? Quote Link to comment Share on other sites More sharing options...
Widelupo Posted March 12, 2011 Author Report Share Posted March 12, 2011 oil in the hole where spark plugs are. the camber belt is due. ill take it to the garage to have a look today and see what the say. Quote Link to comment Share on other sites More sharing options...
Lev Posted October 17, 2011 Report Share Posted October 17, 2011 (edited) Wo wo wo new engine there talking a load of "Rubbish" mate camshaft seal's/ Piston Rings... Edited October 17, 2011 by Lev Quote Link to comment Share on other sites More sharing options...
Douggie Posted October 17, 2011 Report Share Posted October 17, 2011 i have this problem to... doesnt actually seem to be doing anything bad! just a little bit of oil! haha Quote Link to comment Share on other sites More sharing options...
Lev Posted October 17, 2011 Report Share Posted October 17, 2011 /piston rings Quote Link to comment Share on other sites More sharing options...
Douggie Posted October 18, 2011 Report Share Posted October 18, 2011 How muxh and how hard is this to change? Quote Link to comment Share on other sites More sharing options...
Bickerton Posted October 18, 2011 Report Share Posted October 18, 2011 Harder than swapping an engine Quote Link to comment Share on other sites More sharing options...
Rich Posted October 18, 2011 Report Share Posted October 18, 2011 Harder than swapping an engineyup. Quote Link to comment Share on other sites More sharing options...
Lev Posted October 29, 2011 Report Share Posted October 29, 2011 It's not to hard just engine strip down basically Quote Link to comment Share on other sites More sharing options...
Mitchell Posted October 30, 2011 Report Share Posted October 30, 2011 buy some spray brake cleaner place rag over a screwdriver spray inside the plug shaft " with plug in to stop stuff getting in the bore " clean out the hole with rag on screwdriver once all oil is out remove the plug,and replace it. there will be a small lip where the cam carrier meet's the head this is where the oil is seeping through, make sure this is cleaned and smear a light coating of tiger seal/ sikaflex around the join allow this to go off before replacing the plug. job done 20 quid top Quote Link to comment Share on other sites More sharing options...
Bickerton Posted October 30, 2011 Report Share Posted October 30, 2011 I used copper gasket seal to remedy it when this happened to me, its like a fiver Quote Link to comment Share on other sites More sharing options...
