Billster Posted February 23, 2011 Report Share Posted February 23, 2011 I have a old school amp for sale, never been used.....i have not a clue on whats its worth so im saying £60specs4 Channel Mosfet Amplifier PWM Mosfet Power Supply Defeatable Advanced Overload and Thermal Protection Dual Hi Level Input Connections Input Sensitivity Control Advanced Muting Circuitry Eliminates Turn-On And Turn-Off Noises Metal Film Capacitors/Resistors In Signal Path 24kt Gold Plated High Current Power And Speaker Terminals Isolation Mounting Feet Optional XS Link For Seamless Multiple Amplifier Installation Dual Low Pass level control Frequency Response +/-1dB, 20Hz to 20 kHZ Signal to Noise Ratio (A-weighted) >100dB Max Continuous Bridged Power @ 1% THD 300 watts x 2 into 4 ohms @ 14.4 Vdc Max Continuous Power per Channel @ 1% THD 150 watts x 4 into 2 ohms @ 14.4 Vdc Nominal Continuous Power per Channel @ 1 % THD 75 Watts x 4 into 4 ohms @ 14.4 Vdc IASCA/USAC Power Rating 25 Watts x 4 into 4 ohms @ 12.5 Vdc Minimum Load when Bridged 2 Ohms Minimum Load per Channel 1 Ohm Input Signal Voltage Range 0.1 volts to 2 volts Crossover Type Resistor Network, Linkwitz, Highpass/Lowpass Crossover Slope 24 dB per octave Crossover Frequency Range 20-550Hz Factory Crossover Setting 85Hz Auxilary Output Channels 2 Auxilary Output Frequency Range Highpass or Lowpass, Opposite of Rear Bass Boost 0- to +18dB @ 45 hZ Power Supply Voltage 10Vdc to 15.5Vdc Recommended Fuse 60 amp Dimensions 14.25L x 9.25W x 2.10H Quote Link to comment Share on other sites More sharing options...
Alidila Posted February 24, 2011 Report Share Posted February 24, 2011 pm'd Quote Link to comment Share on other sites More sharing options...
Billster Posted February 24, 2011 Author Report Share Posted February 24, 2011 sold Quote Link to comment Share on other sites More sharing options...
