Sara Posted January 7, 2011 Report Share Posted January 7, 2011 Just finished work came to the car - heard it was making a 'dinging' noise like if you leave your lights on and get out of the car. Blipped the key fob button and nothing happened.... did it again and it opened the car but all the lights were lit up on the instrumental panel. Drove back home no problems what so ever. Parked up and went inside nxt thing the alarm was going off. My BF went out to turn it off but the fob wouldn't work. After a few seconds the alarm stopped but all the lights were on the dash again?Tried the key fob again and the car locked and unlocked? went to start the car and it wouldn't start... just turn over nothing else.... Could t be the key fob battery causing the fault Quote Link to comment Share on other sites More sharing options...
Pete Posted January 8, 2011 Report Share Posted January 8, 2011 Does the dash have a little key icon come up on the display with the ignition on and when you try to start it? Quote Link to comment Share on other sites More sharing options...
Sara Posted January 8, 2011 Author Report Share Posted January 8, 2011 Right well its not the battery! just been to get a new car battery and a key fob battery put them both in few noise's happened went to lock the car.....nothing! the key doesn't work at all.The EPC, Exhaust Emissions and hand brake lights are on constantly even with the key out???? Quote Link to comment Share on other sites More sharing options...
ChristopherReeve Posted January 8, 2011 Report Share Posted January 8, 2011 Is A Wire Been Damaged Or Anything Possibly? Quote Link to comment Share on other sites More sharing options...
Sara Posted January 9, 2011 Author Report Share Posted January 9, 2011 Unsure as its been fine up until now! Quote Link to comment Share on other sites More sharing options...
ChristopherReeve Posted January 9, 2011 Report Share Posted January 9, 2011 Hope It Stays Fine For You Quote Link to comment Share on other sites More sharing options...
Sara Posted January 9, 2011 Author Report Share Posted January 9, 2011 Think you misunderstood me, the cars been running fine until this started....... checked all the fuses - they are all ok Quote Link to comment Share on other sites More sharing options...
RobG Posted January 9, 2011 Report Share Posted January 9, 2011 Do you have any water ingress, or are your plenum drains blocked? On a passat misc gremlins like this are usually down to a soaked CCM module under the passenger side seat. Not sure where the lupo one is though. How are your battery connections? My pug's dash used to go mental every once in a while, was down to dirty battery terminals so not making a good connection. Quote Link to comment Share on other sites More sharing options...
John West Bear Posted January 9, 2011 Report Share Posted January 9, 2011 The CCM module is behind the Fusebox on the drivers side part of the Dashboard. Checked all Fuses etc? Quote Link to comment Share on other sites More sharing options...
RobG Posted January 10, 2011 Report Share Posted January 10, 2011 The CCM module is behind the Fusebox on the drivers side part of the Dashboard. Cool, ta. Guess it's probably not drowning, if it's located there. Quote Link to comment Share on other sites More sharing options...
John West Bear Posted January 11, 2011 Report Share Posted January 11, 2011 Well my CCM has to be replaced - The symptons for mine were battery draining flat, the key fob wouldn't light up, when it did work the LED was perm on. The alarm would go off intermittently. THe immo box is seperate though so the car would start but the actual car was a pig just because it made me look like I had stolen the car! Quote Link to comment Share on other sites More sharing options...
Sara Posted January 20, 2011 Author Report Share Posted January 20, 2011 All fixed now! found out it was the wiring loom to the door/inside the door! it was (to put it politely) buggered..... so new one in and all fixed! Quote Link to comment Share on other sites More sharing options...
