Defcon5 Posted January 23, 2011 Author Report Share Posted January 23, 2011 There isnt anything obvious, I have had the car in the air and had a proper shufty.Will get the alignment checked and go from there. If the subframe is fubar they should be able to tell straight away I would imagine Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted January 24, 2011 Author Report Share Posted January 24, 2011 Try what i said, for the sake of £7 each or something?Track rods themselves are quite expensive, unless you just mean the track rod end? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 24, 2011 Report Share Posted January 24, 2011 Track rods are £80+ each from Lupoboz I think. I did get a quote. Can't see thats the cause anyway.Get it on somebodys 4 wheel lazer wheel alignment, That will soon tell you if something is bent. Quote Link to comment Share on other sites More sharing options...
DANIELP1991 Posted January 24, 2011 Report Share Posted January 24, 2011 the garage should have done the tracking if theyve had the wishbones off.garanteed it will be out.whats your tyres like, tread wise and pressures?it will drive **** if they are worn out like and if you got say a crap tyre on theleft and a good tyres on the right if you get me??have you checked everything else for play etc..? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted January 24, 2011 Author Report Share Posted January 24, 2011 the garage should have done the tracking if theyve had the wishbones off.garanteed it will be out.whats your tyres like, tread wise and pressures?it will drive **** if they are worn out like and if you got say a crap tyre on theleft and a good tyres on the right if you get me??have you checked everything else for play etc..?Yes, they tracked it up, need to get it on a computer controlled lazer rig though.No issues with tyres, apart from they were on the wheels I bought and as such I dont know the history of them Quote Link to comment Share on other sites More sharing options...
DANIELP1991 Posted January 24, 2011 Report Share Posted January 24, 2011 wont make much difference whether you have it done on a computer one or just the little laser gauges like i got in work.much be a bush gone somewhere or something.u need to get everything checked make sure its all straight.its a bit weird tbh. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted January 24, 2011 Author Report Share Posted January 24, 2011 wont make much difference whether you have it done on a computer one or just the little laser gauges like i got in work.much be a bush gone somewhere or something.u need to get everything checked make sure its all straight.its a bit weird tbh.I want a printout showing the geo, hence the computer comment. I have replaced the wishbone bushes. May do TREs dependant on alignment results - or should I do them now anyway? Quote Link to comment Share on other sites More sharing options...
treblet Posted January 24, 2011 Report Share Posted January 24, 2011 I'd get the geometry done first then take it from there, I didn't realise you hadn't had this checked already!I've driven my car (after replacing the subframe) with so much negative camber on the left that it was off the scale on the computer print out! I also had a fair bit more than is advisable positive camber on the right and it pulled like hell but looked reasonably normal when parked up! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted February 2, 2011 Author Report Share Posted February 2, 2011 Alignment results are in...FrontCamber -2.03 -1.57Caster 1.37 1.38Toe -0.01 -0.01RearCamber -1.45 -1.28Toe -0.04 -0.02Guys boss was in and said they wouldnt let him adjust the aftermarket suspension (computer says no), but could half a degree of camber cause this?Least there isnt anything up with the subframe etc. Quote Link to comment Share on other sites More sharing options...
treblet Posted February 2, 2011 Report Share Posted February 2, 2011 Yep the camber looks to be the problem, your front and rear camber is out by a fair bit on the near side.I think mine was around -3.5/-4 on the front left when I fitted the new subframe, it pulled like mad!! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted February 2, 2011 Author Report Share Posted February 2, 2011 excellent. Is the rear worth bothering with, and if so, are shims the only solution? Quote Link to comment Share on other sites More sharing options...
bikemad04 Posted February 2, 2011 Report Share Posted February 2, 2011 Sure they used camber bolts when doing mine. Quote Link to comment Share on other sites More sharing options...
treblet Posted February 2, 2011 Report Share Posted February 2, 2011 There's nothing adjustable on the rear so if you really wanted to adjust it shims would be the only way to do it.Personally I wouldn't bother doing the rear. I can't see why they wouldn't adjust the front though, quite pathetic some of the excuses some garages come up with! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted February 2, 2011 Author Report Share Posted February 2, 2011 There's nothing adjustable on the rear so if you really wanted to adjust it shims would be the only way to do it.Personally I wouldn't bother doing the rear. I can't see why they wouldn't adjust the front though, quite pathetic some of the excuses some garages come up with!They appeared to be undergoing some kind of inspection, wouldnt even let me on the shop floor!I assumed they were H+S Nazis Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 2, 2011 Report Share Posted February 2, 2011 Did you get a print out showing the results? Does it show the thrust angle?What suspension do you have? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted February 2, 2011 Author Report Share Posted February 2, 2011 thrust angle is 0.01This is my suspension http://www.europerformance.co.uk/pages/products/product_info.mhtml?product=15348350 Quote Link to comment Share on other sites More sharing options...
DarkStryder360 Posted February 2, 2011 Report Share Posted February 2, 2011 £200 for a subframe! You mad! I bought one on eBay for £60 and it's good condition Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 3, 2011 Report Share Posted February 3, 2011 thrust angle is 0.01This is my suspension http://www.europerformance.co.uk/pages/products/product_info.mhtml?product=15348350Nothing can be that bent then.£200 for a subframe! You mad! I bought one on eBay for £60 and it's good condition How do you know it's straight? Quote Link to comment Share on other sites More sharing options...
DarkStryder360 Posted February 3, 2011 Report Share Posted February 3, 2011 It doesn't look f**ked like mine for starters lol Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted February 5, 2011 Author Report Share Posted February 5, 2011 Been reading up online, and the general concensus is that the car should pull toward the side with the most positive camber, but mine does the opposite? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 5, 2011 Report Share Posted February 5, 2011 Been reading up online, and the general concensus is that the car should pull toward the side with the most positive camber, but mine does the opposite?Usally does yes. adjust it your self a tiny bit, see if it makes any difference. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted February 5, 2011 Author Report Share Posted February 5, 2011 I had considered that, but Im not sure that Ill be able to crack the bolts, I would imagine they are on massively tight to prevent them moving as you drive. I only have spanners, the pikeys stole my scaffolding polo/breaker bar Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted March 23, 2011 Author Report Share Posted March 23, 2011 And so the saga continues...Now changed the front top mounts and bearings (one was split, though I was onto a winner there!) and the track rod ends to no gain.The front passenger shock has started to leak, which is just adding to my misery. Could it be this that is causing all my problems?So, to recapChanged:TyresSuspension alignmentTrack rod endswishboneswishbone bushestop mounts & bearingsSeem Okhubswheel bearingsNeeds Attention:FNS shockMy love for the car Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted April 4, 2011 Author Report Share Posted April 4, 2011 Gearbox mount arrived today, will fit that as soon as I get my jacks back. I dont even think it will make a difference, but Im past caring to be honest.I am running out of things to replace here, and its really pissing me off. Quote Link to comment Share on other sites More sharing options...
NOCK Posted April 4, 2011 Report Share Posted April 4, 2011 Might sound really stupid, but is your steering wheel straight and are your brake pads clearing the discs on both sides? Quote Link to comment Share on other sites More sharing options...
