Richud Posted November 21, 2010 Report Share Posted November 21, 2010 (edited) im fitting powerfler bushes to my gti today and it appeares that i have to remove the plastic tray under the engine to be able to undo the bolt that holds the wishbone on.its a bit of a bitch and i wasnt expectng it, how do i remove it? Edited November 21, 2010 by Richud Quote Link to comment Share on other sites More sharing options...
lupoluke Posted November 21, 2010 Report Share Posted November 21, 2010 (edited) There should just be several screws around the edges of the tray (T25`s off the top of my head), just undo them and it will drop down.edit - sorry for some reason i was thinking about a polo when i wrote this. Edited November 23, 2010 by lupoluke Quote Link to comment Share on other sites More sharing options...
Richud Posted November 21, 2010 Author Report Share Posted November 21, 2010 yer i had one side jacked up at the time so i couldnt really look rite underneath, will have to put it on the ramps before i take the wheels off next time lol. Quote Link to comment Share on other sites More sharing options...
jon_273 Posted November 21, 2010 Report Share Posted November 21, 2010 The undertray just has two 10mm (maybe 13mm?) bolts at the back near to where the wishbones mount to the subframe.Then just give it a pull and the metal spidery things will pop off. Sounds weird but thats the only way I can think to describe it at the moment Quote Link to comment Share on other sites More sharing options...
Richud Posted November 22, 2010 Author Report Share Posted November 22, 2010 The undertray just has two 10mm (maybe 13mm?) bolts at the back near to where the wishbones mount to the subframe.Then just give it a pull and the metal spidery things will pop off. Sounds weird but thats the only way I can think to describe it at the moment ahh i saw those metal spidery thing so i know exactly what your on about lol. cheers Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 22, 2010 Report Share Posted November 22, 2010 I must say, I know exactly what you meant by the spidery things! Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted November 23, 2010 Report Share Posted November 23, 2010 (edited) There is one that Is accesible if you turn your steering wheel all te way to the right you will see it in your driver side arch Edited November 23, 2010 by jamiea7x Quote Link to comment Share on other sites More sharing options...
