jennings1992 Posted August 9, 2010 Report Share Posted August 9, 2010 may seem like a really daft question but wheres the fusebox on a lupo? iv found the 4 fuses on the battery and the small fusebox on the right hand side of the steering wheel but i cant find the main fusebox with the relays etc in? does a lupo not have one or am i not looking properly? Quote Link to comment Share on other sites More sharing options...
williamz Posted August 9, 2010 Report Share Posted August 9, 2010 only main one i know of is by the steering wheel bud. Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted August 9, 2010 Report Share Posted August 9, 2010 The relays are located behind the fuse box under your steering wheel . Quote Link to comment Share on other sites More sharing options...
jennings1992 Posted August 9, 2010 Author Report Share Posted August 9, 2010 ah alright cheers i was expecting a bigger fusebox like a real car would have ill have a quick checkl of my relays now and if i find nothing ill have to chuck it on a ramp tomorro, starter motor went caput the day befor usc cheers anyway Quote Link to comment Share on other sites More sharing options...
RobG Posted August 9, 2010 Report Share Posted August 9, 2010 The relays are located behind the fuse box under your steering wheel .Just so. You'll need to take the parcel shelf bit off to get proper access to them. Quote Link to comment Share on other sites More sharing options...
jennings1992 Posted August 9, 2010 Author Report Share Posted August 9, 2010 yep got that now pain to get to but iv got to the relays, anyone know which relays for the starter motor? assuming the starter has a relay? theres only 3 but i cant figure out the diagram on one to test it Quote Link to comment Share on other sites More sharing options...
jennings1992 Posted August 9, 2010 Author Report Share Posted August 9, 2010 turns out i wasted my time remembered a mate had a problem with his ignition switch on his polo after id had the dash out so thought id try it and sure enough it worked so its rigged up with a wire for now cheers all that helped Quote Link to comment Share on other sites More sharing options...
