! Help Needed ! Engine Swap ? ? ? ?
lupilupo
Hi Guys,
Sorry to bither you all!
My Lupo Sport has been written off by the insurance and as it goes my Girlfriends has just blown up her Lupo 1.4s.
I've bought back the salvage - as the title says, does the 1.4 16v Sport fit into the 1.416v S?
Obviously i have both whole motors, if it does, are there any mods needed doing to make it fit, just it's cheaper than buying and or fixing her Lump.
All commect appreciated and taken on board.
Thanks in advance.
Cheers,
Nick
Edited by lupilupo
The engine will drop straight in, the mounts are the same, both gearboxes will fit however the sport gearbox has shorter ratios. The injection and ignition systems will have to be taken from the sport ie engine bay wiring loom, inlet manifold and tb, ecu etc, and you could either swap the immobilizer and clocks from the sport into the 's' or you could find someone with a fully licenced vag com to adapt the 's' immobilizer to work with the sport ecu.
Hope this helps, Mark
